throttle body???
Old Feb 16, 2007 | 06:41 PM
tommyt's Avatar
tommyt
Default throttle body???
what throttle body do you use off the mondeo when you are using it as an upgrade on an xr2i 1800 zetec
Old Feb 16, 2007 | 07:21 PM
Wardy257's Avatar
Wardy257
Changing the TB alone will make no difference. You need the TB, cams and ECU from a 130 bhp spec 1.8 ZETEC. You can use the early 2.0 ltr cams as they are the same.
Old Feb 17, 2007 | 09:56 PM
tommyt's Avatar
tommyt
im putting a 2l lump in just need to now what tb to use
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
