fuse board diagram for mk5a XR3i cabbie
Old Feb 15, 2007 | 08:58 PM
danelliott's Avatar
danelliott
Default fuse board diagram for mk5a XR3i cabbie
I have been trying to find if my electric window fault is caused by a fuse problem,
Thing is i have checked all my fuses, ive even taken every single fuse out 1 by 1 and tried the windows and the rear windows work even with every fuse taken out individually but the front windows still do not operate.
I have posted in this same section a please help me post but this one is asking for a diagram of the mk5a 1.8i XR3i Cabbie fuse board. The Haynes manual i have is damaged and i have no diagram of the fuse board for this vehicle it is a K (93) reg and from what i can gather from reading the Haynes the fuse i should be looking at is the fuse in number 22 slot, which is a 30A blade fuse.
This is the first fuse i tried but still no luck.
I know i can try checking the live feed to the switches but i just find it odd that both rear windows operate but the front 2 do not.
By the way....... Prior to the failure of the front windows i had a problem with them where they would only operate if the driver door was open, ie when the interior curtosy light switch on the body by the door was released. that is when you open the door and the interior light comes on.
N e helpful diagrams or links to diagrams would be very much appreciated.
Many thanks
stephenb4506
33
Oct 2, 2015 06:25 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
