wheel wobble!
Feb 15, 2007 | 08:23 PM
wheel wobble!
got a fairly bad wheel wobble after having my cv joint replaced guna take it bk to the garage where the work was done, just wonderin if any 1 has a rough idea wat it cud be
Feb 15, 2007 | 09:59 PM
loose wheel nuts
or loose drive shaft nut
Feb 16, 2007 | 03:22 PM
Take it to Chemix they will fix it
May 10, 2007 | 07:43 PM
May 12, 2007 | 08:57 PM
could be cv joint or a wheel bearing
May 13, 2007 | 09:35 PM
Last time I had that was when the hub nut had came loose because it wasn't pinched in to the recess on the threaded end of the driveshaft
May 28, 2007 | 12:06 PM
Could be the ball joint on the lower arm too. I've just had that problem on my Escort
Fiddy
21
Sep 29, 2015 06:10 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
