clutch adjustment
Clutch is self adjusting so it probably means your clutch cables stretched or your clutch is on the way out.Iv,e converted mine to a MK6 ESCORT CLUTH PEDDLE which you can adjust yourself.
I have similar prob
I changed my gearbox for an lsd gearbox on my s2, since I must press the pedal at bottom to de-clutch, my clutch is a reinforced ap racing and it has 2k miles, my clutch cable is tended and the lever of selector on the gearbox move a little when I declutch
how to adjust the clutch guard? The self adjust doesn't seems to work
If you've got strange biting points its probably cos your teeth have broken on your quadrant.
Id rather have it low down than at the top of the pedal though, at least you know your clutch is ok
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
