Any point
hi i'm thinking of buying a -34 actuator as at tho moment i'v got the standed one that henry ford fitted but i'm wanting to know if this is the right thing to do as my head has had no work done to it the is cam even standed.It's been chiped and it's going to have a grs cooler fitted, the reson i'm thinking of fitting a -34 instead of a -31 is so i can boost over 15psi will this be ok???
oh it allso has a bleed valve.
head work and a new cam is on the menu later date tho.
