GOT IT RUNNING AT LAST
Old Feb 14, 2007 | 02:27 PM
khanny's Avatar
khanny
Default GOT IT RUNNING AT LAST
Got the frst turbo bottom on at last and running thing is out all the plugs at the back of the inlet manifold i was left with the blue 1 and cant find were it goes it all seems to be running fine just takes a couple of times to stray ticking over when starting, any1 know were it goes
also im runnig 0.7 bar does this mean the ecus chipped
plus any1 know were ican get the oil return not the pipe but the metal tube that goes into the block as bent mine removing it from the block and now leaking a bit of oil on to the down pipe
Old Feb 14, 2007 | 02:46 PM
y4n's Avatar
y4n
It might be the cold start injector plug
Old Feb 14, 2007 | 02:50 PM
khanny's Avatar
khanny
DO YOU KNOW WERE IT GOES M8
Old Feb 14, 2007 | 02:51 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
it will be the cold start plug.
right in the middle of the inlet between the ports on the upright part facing up the way! follow the 5th red fuel hose to the inlet.
Most of the time the CSV doesnt work properly and is best left unplugged but plug it in to see if it starts better with it on.
Old Feb 14, 2007 | 03:00 PM
twinkle_2k86's Avatar
twinkle_2k86
Default Re: GOT IT RUNNING AT LAST
here you go,
OIL RETURN CONNECTOR (1592381) Ł0.83
still get them from fords, as i got 2 for when i was building a ZVH and needed a oil return in the block.
Old Feb 14, 2007 | 03:46 PM
khanny's Avatar
khanny
vroooom ptssssh
i got 1 pluged in there i think its yellow
and
twinkle_2k86 went to ford this morning they sayed they dont do them any more
Old Feb 14, 2007 | 04:56 PM
vroooom ptssssh
It Wasnt Me!
khanny, The yellow one goes on something else, their is a yellow sensor below the cold star valve facing into the head! iirc, if not its around their somewhere, I might be thinking about the brown thermo time switch
Old Feb 14, 2007 | 05:17 PM
gup's Avatar
gup
the blue one is the cold start valve
the yellow is the water temp senser at the bottom of the inlet at an angle
the brown one is the thermo time switch
the black one is the auxirly (spelling) air valve which sits under the inlet and has the 2 hard plastic pipes on to it
Old Feb 14, 2007 | 05:41 PM
davidnormanuk's Avatar
davidnormanuk
All the plugs should be colour coded.
Old Feb 14, 2007 | 05:55 PM
gee1599's Avatar
gee1599
i got one from ford 2 days a go but had to order 10 of them i can sell you one if you wont
Old Feb 14, 2007 | 06:58 PM
SafeChav's Avatar
SafeChav
Its not they don't work, they just flood the engine
Its a problem across the Bosch K/KE Jetronic range, its not just our crappy Fords for once
Old Feb 14, 2007 | 08:20 PM
khanny's Avatar
khanny
all the others were colour coded its i just cant find 1 for the light blue plug
Old Feb 15, 2007 | 02:02 PM
SafeChav's Avatar
SafeChav
Wouldnt worry about it mate it will probably be better off without!
You need to make sure you have the yellow plug on the correct sensor though, and it is a slag to get to
Old Feb 15, 2007 | 03:21 PM
davidnormanuk
Its easier to get to it from underneath the car.
Old Feb 17, 2007 | 11:21 AM
gee1599's Avatar
gee1599
is this what you need?
Old Feb 17, 2007 | 11:26 AM
gee1599's Avatar
gee1599
if you need one give me a pm
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
