lowered S2
Old Feb 13, 2007 | 08:09 PM
e900 ddv's Avatar
e900 ddv
Default lowered S2
lets see your lowered series 2's as i'm going to be doing mine but dont know how much to do it. lets have pics and details on how low and what size wheels. mine will be on 17" kahn rsr's or 16" mondeo 5 spokes.
Old Feb 13, 2007 | 08:23 PM
jamie rst's Avatar
jamie rst
Heres one of my old one lowered 60mm with 17's inch wheels
here is my current one lowered 20mm with 17's inch wheels but i am in the middle of restoring it at the moment, when i have finished it will be lowered 40mm or 60mm with 18's inch wheels
Old Feb 13, 2007 | 08:38 PM
makaveli96's Avatar
makaveli96
With my 17'' alloys I've put on Koni adjustable shocks with 30mm Eibach springs but the springs never lowered the car enough so took them off and had to settle with PI springs but if it's sitting too low at the front you will have problems, to sort that out I had to buy a pair of front adjustable track control arms which are very expensive but will solve the problem, along with Powerflex bushes at the front, with this set up it does make a massive inprovement in handing and never rubs at the front or back even with 5 people with No arch mods. hope that helps
Old Feb 13, 2007 | 08:48 PM
Brian's Avatar
Brian
Our's is lowered 35mm
Brian
Old Feb 13, 2007 | 09:19 PM
K3V HA's Avatar
K3V HA
Heres my old one, lowered 35mm on knackered suspension! Had it on coilovers after them, it handled great on them and look as sweet!
Old Feb 13, 2007 | 09:25 PM
makaveli96's Avatar
makaveli96
Hi mate, the Koni's on my car is quite a hard ride but I heard the coilovers are even more harder than the Koni's what would you say in your opinion because i was going to get them but it put me off a bit.
Old Feb 13, 2007 | 09:28 PM
K3V HA's Avatar
K3V HA
In my opinion mate, the coilovers were alot nicer! Car handled sooo much better withem 2, get them corner weighted if you get some too, it is well worth doing and made my rise soooo much more comfy, the Konis were horrible on that before i changed em!
Old Feb 14, 2007 | 05:32 PM
rsdan's Avatar
rsdan
Heres mine. lowered wiv Avo 25mm springs n koni shocks
Old Feb 14, 2007 | 05:50 PM
C241G-RS's Avatar
C241G-RS
Here's a couple of my old turbos....
First one is lowered 25mm with Eibach springs and Koni adjustable shocks on standard S2 wheels
Second one is lowered 35mm with same shocks/spring set up sitting on 17" Ace 112's
Hope it helps
Craig
Old Feb 14, 2007 | 07:02 PM
mercury grey minter's Avatar
mercury grey minter
Lowwered 25mm with KONI adjustables.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
roomey
Sep 19, 2015 08:40 AM
