speed idle
Old Feb 13, 2007 | 01:24 PM
kurdt5's Avatar
kurdt5
Default speed idle
my S1 is sat at 2000rpm when standing. How do i turn it down?
Old Feb 13, 2007 | 01:59 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
There is a screw on the throttle body that bleeds air. Adjust that, it should be finger tight and near the throttle cable, if I remember correctly.
Old Feb 13, 2007 | 05:21 PM
fast_ford_uk's Avatar
fast_ford_uk
like above -on the right hand side of before the plenum chamber as your looking towards the car
Old Feb 13, 2007 | 05:43 PM
Dragsteer's Avatar
Dragsteer
can someone write me where is this screw? is that screw under butterfly, which stands vertically and have spring on it?
isnt that for choke?
little spring on left side of butterfly is for idle , isnt? number 8 key
Old Feb 13, 2007 | 05:52 PM
Tony Turbo's Avatar
Tony Turbo
Hot digidy... You've found it!
Old Feb 13, 2007 | 05:57 PM
zippyobrien's Avatar
zippyobrien
i had the same problem on mine, turns out the throttle cable was poorly adlusted, worth trying that to, left hand side of the throttle bodie
Old Feb 14, 2007 | 09:45 AM
Dragsteer's Avatar
Dragsteer
how you mean throttle cable wasnt adjusted? maybe on idle cable was opening butterfly?
Old Feb 15, 2007 | 07:30 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Automatic choke mate. That's the idle adjuster.
Old Feb 15, 2007 | 08:38 PM
Dragsteer's Avatar
Dragsteer
thanks. I cannot set up idle, I try to "set up" idle, co, and now my engine wont start, very hard to start, idle very rough....
why whyy
Old Feb 15, 2007 | 10:05 PM
SaqsS2turbo's Avatar
SaqsS2turbo
my one takes the piss to start cranks for a 10 12 secs then starts any one know why?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
routemaster
Sep 7, 2015 05:27 PM
