if i set to 10psi do i need a setup?
ive just not so long ago fitted a rst engine was wondering if i need to get a setup if i set the boost to 10psi?
thanks in advance
thanks in advance
I would say yes. I thought mine went well as standardish, but when it was being tuned for more power the clutch started slipping. PJ put it back to standard till I got paddle clutch and the dif was remarkable. Just a lot smoother, timing absolutely spot on, used less fuel, more linear power delivery. I am now an absolute advocate of a proper set up by a well known tuner.
ill do it for ya, have to see in mr alex will let you use his wideband, and il adjust the fuel for you in it needs it
if i can find one, and some knob will buy my ped, then ill buy a wide band my self, fancyed one for a while now, especially seeing as the old mans skyline is going single turbo
imho id get it done mate, just for peace of mind
i had my s2 done and it went a lot better
its just a reassurance thing for me at least i know its been checked over
Amit
Amit
truffleshuffle
Sep 10, 2015 09:35 PM
