OIL PRESSURE
Old Feb 12, 2007 | 04:59 PM
robbob's Avatar
robbob
Default OIL PRESSURE
What pressure should my gauge read tick over and driving 4x4 cosworth
Old Feb 12, 2007 | 06:46 PM
righthooker's Avatar
righthooker
thy can varey,depending upon engine condition.
Mine reads 4bar on tickover,and 7.5 when driving at a constant speed.Thats a 2wd ,but shouldnt be much diferent to 4by
Old Feb 12, 2007 | 07:14 PM
DAN P's Avatar
DAN P
any thing around 30 psi on idea is fine i think m8
Old Feb 12, 2007 | 09:44 PM
simonc's Avatar
simonc
As above, around 30 psi at idle is about the norm when hot. 4 bar at idle when hot Jesus would say thats a bit high
Simon.
Old Feb 13, 2007 | 07:30 AM
4 bar ridiculously high and 7.5 bar when driving stupid using a lot of power to run pump, does not need anything like this pressure.
Hot idle of 1 1/2 bar normal and ok 3 bar when driving minimum 4 bar better.
ps most likely an inaccurate guage at 7.5 bar
Old Feb 13, 2007 | 10:01 AM
JanDK's Avatar
JanDK
Could it be an uprated pump then?
Old Feb 13, 2007 | 05:36 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Oil grade is also a factor
7.5 bar Thats 110 psi
An uprated pump is usually 80 psi on throttle so maybe your gauge is faulty
Mine is 55psi when start up, and 20 psi when cooked
Ive been told and reasured that this is the "normal" type of oil pressure so im happy
Old Feb 14, 2007 | 08:55 AM
b_kennedy's Avatar
b_kennedy
what about on a 2.1 zvh escort rst. thanks
Old Feb 14, 2007 | 03:34 PM
Could be an uprated pump but this is ridiculous pressure and not needed, it may well airate the oil and lose wedge because of this, it also uses power to run.
As said 20 PSI hot and 60 PSI running above 2500 perfectly fine .
Old Feb 15, 2007 | 08:14 PM
righthooker
Engine is a fresh rebuild ,now got 2.5k on it and my guage reads 4bar and nearly 7 at revs .
Pump is new too.
If its to high i am sure my engine builder would have said so and corrected it
i wont even bother to ask him
Old Feb 15, 2007 | 08:16 PM
rapidcossie's Avatar
rapidcossie
i have a high pressure pump.
i see 70 psi at cold start and 25- 30 psi at hot idle
Old Feb 16, 2007 | 03:07 PM
It is most likely just a inaccurate guage.
Old Feb 18, 2007 | 01:18 PM
BIL N KEL's Avatar
BIL N KEL
same here
Old Feb 18, 2007 | 01:39 PM
rabmc's Avatar
rabmc
80 when starting up , and 35-45 roughly when hot and idleing
On full chat it hits 80
SMILER258
Sep 28, 2015 09:04 AM
