2wd engine, £800
can be seen running, this engine still in my saff,
now, the engine is fine, but the oil pump has gone a bit tired giving oil pressure readings that change from 60-40 from cold and all over the show,
i basically noticed it as i always check oil pressure, and turned it of and gott owed home, so there is no crank damage etc
comes with inlet and exhaust manifold, sensors, dizzy etc.
car has just been set up at MSD a week ago, so engine is good or they would of told me, new CPS, new Air temp sensor,
i pressure tested it and got 150psi on every bore
rebuilt 20k ago by PJ motorsport, Group A headgasket, ported head (apparently, need to check documentation)
has a blue rocker cover with hole in for breather pipe
£ 800 ono,
07738 445649, pref 12.15 till 1 or after 5
Andy
£ 800 ono,
Andy
rog
Sep 4, 2015 12:10 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Ben26
Aug 27, 2015 08:56 PM
lockie
Jul 31, 2015 10:03 PM
