OMG...this is stunning :-O
Lancashire
Price:
£12000 ovno
Description:
1972 Ford Escort Mk1( tax exempt), Clubman Gp4, Steel arched in gleaming Signal Yellow. Big G box and diff tunnel, round turretts, 4 linked, panhard rod ( gartrac), fully seamed welded and gussetted/ strengthend in right places, period SD bolt in cage and door bars, F Glass bonnett and boot ( steel ones can be supplied). Shell absolutely mint above and below, Tinted screen, poly carb in doors, twin dash and console fully fused and wired, kevlar floor panels, new seats 6 pnt 3in Q R belts fully e-quipped fuel and brakes, varley battery electronic cut-off, and extinquisher, carbon door panels. Engine Toyota 4AGE- 170 bhp at wheels on 45mm throttle bodies, cams verniers etc ported head etc, DTA mapped ign and fuel, paddle clutch HD Cover, 4:1 exhaust, Gartrac safari rad. 5 speed Quaife pro, 5:1 Atlas single prop, suspension 2 1/4 coil over front and rear, Rtms, alloy hubs, gp 4 studs adjustable tca's TC ARbar wcxm kit 4 pots q rack, DW kit, bias pedal box (hyrd)hydr handbrake, rear discs and calipers. Kevlar sump guard, wheels 7 x 15 GP 4 Compomoive MLs with TA00's. This car has done two events from build and can only be described as pristine and ready to rally, could easily be converted to historic spec if desired. Contact Dave.
Originally Posted by Daveyboy
well yours is gonna be worth about as much as a chav'd up corsa when you get it back
Spiky, do you still need those bits that fell of Co's car?
Sorry Spiky just found this from a search....
My mate built it it's his car
It sadly went to Ireland for A LOT less than that
I did post some pictures of it on here somewhere ages ago now
And for the record ..... it was a stunning car and a credit to you Dave
It was only for sale because he was trying to save his marriage at the time, she said it had to go
- it went........ then she f**ked off with another fella
STAFFY OWNER
Sep 13, 2015 08:59 PM
noooooooooooooooooooooo
