brake bleeding
Old Feb 11, 2007 | 06:35 PM
steveo135's Avatar
steveo135
Default brake bleeding
does anyone know the correct procedure to bleed brakes on a 2wd saff.
cheers
steve
Old Feb 11, 2007 | 07:11 PM
I just do mine using the ABS pump starting with nearest and working next nearest etc, always works for me.
Old Feb 11, 2007 | 07:15 PM
Alvyn's Avatar
Alvyn
turn ignition on and bleed fronts as normal ie pressing up/down a few times and then holding down open nipple and see the fluid flow out without any bubbles the rears will bleed by opening the nipples one at a time on the caliper and pressure from pump will push fluid along with any air out just make sure reservoir's topped up.
Old Feb 11, 2007 | 11:26 PM
SafeChav's Avatar
SafeChav
Im the daddy at bleeding brakes apparently
(See my siggy)
Old Feb 12, 2007 | 06:18 PM
fast_ford_uk's Avatar
fast_ford_uk
(See my siggy)
note to self-do NOT take brake bleeding advice from this person lmao
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
