running out of fuel
Old Feb 11, 2007 | 05:50 PM
crash_ash's Avatar
crash_ash
Default running out of fuel
been to my car today to give it a quick run, started to splutter, so i swirched off and returned with 5 litres of fuel, no joy, another 5 litres of fuel and still she wont start.
Cranking occaisionally fires and no smell of petrol, but wont start.
I'm sure i've done this before and made a mental note (which i've forgotten) not to let it happen again. I think last time i had to put maybe 20 litres in it to get it going again.
Am i on the right track or shall i just drag her round the block on the back of my truck?
Old Feb 11, 2007 | 06:15 PM
Listen for fuel pump priming, if it is not you may have dodgy CRANK SENSOR CONNECTOR, give it a wiggle to see if it helps.
if getting no CPS signal then it will not prime as mine did not and had same problem, changed connector perfect ever since.
Old Feb 12, 2007 | 06:26 PM
crash_ash's Avatar
crash_ash
primes for a short period of time before cranking and i slightly lomg period when i stop it cranking
Russ Hill
Aug 31, 2015 06:44 PM
ekjim
Aug 17, 2015 08:57 PM
RSMK4TURBO
Aug 13, 2015 08:06 AM
Zoggon
Aug 10, 2015 10:39 AM
ginger1979
Jul 31, 2015 09:56 PM
