What does this do?
Old Feb 11, 2007 | 03:37 PM
LukeT's Avatar
LukeT
Default What does this do?
Hi all i have a new 500 cooler to fit soon just wondering wat to do with this anyone know what it does can i get rid of it or will it need relocating it sits on the top of the cooler has one pipe to the turbo housing one to actuator and one to the air box!
The air box one will have to go anyway as im soon putting big K&N on!
Cheers Luke.
Old Feb 11, 2007 | 03:44 PM
trevCOSS's Avatar
trevCOSS
its the amal valve, its the ecu's way of controlling your boost, it allows higher boost in the mid range and then to drop it off higher up etc, you dont want to just get rid off it unless your going to replace it with something else. just make a bracket up and locate it there or move it somewhere else
Old Feb 11, 2007 | 03:47 PM
LukeT's Avatar
LukeT
thanks mate!
Old Feb 11, 2007 | 10:17 PM
bud-weis's Avatar
bud-weis
Football Cwazy
also you can just remove the pipe going to the airbox (you won't be needeing it once the cone filter is fitted)
Old Feb 12, 2007 | 12:10 AM
COSSIE 1's Avatar
COSSIE 1
auto specialist sell a nice shiney adaptor for the amal valve that will allow fitment once the 500 cooler is fitted ,looks
Old Feb 12, 2007 | 03:27 PM
LukeT's Avatar
LukeT
hey guys if i was to relocate this valve would it affect the working of it if the pipework was lengthend?
