My Magenta 4x4 cossie project "Geurnsey" Its runni
Old Feb 11, 2007 | 02:25 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default My Magenta 4x4 cossie project "Geurnsey" Its runni
As most of you know i bought a Sierra Cosworth 4x4 1990 fairly cheap went to go through MOT and failed on a lot of things.
So im going to give it a general tidy up and get it back on road.
Things that need doing
Replace all brake pipes and flexi hoses with goodridge ones
repair both inner sills
repair any rust or corrosion underneef!
Figure out why ABS light stays on.
Fit new heater matrix
spray spoiler and boot as they become a bit scabby.
this is what it looked like when i bought it
these were the sill and brake pipes it failed mot on
The underside
Just purchased these
Now for the brake lines so off comes wheel and inner covers and
WTF
Multicoloured inner arch
give the underside a jet wash very breifly and come out ok really
Cut away some little rust holes in the inner wheel area ready to weld tommorrow
and this is how i left her today
Old Feb 11, 2007 | 02:34 PM
coco16i's Avatar
coco16i
Looks a tidy motor mate and you will have them pipes and welding done in no time and be back on the road again shortly.
Old Feb 11, 2007 | 07:02 PM
Neil S's Avatar
Neil S
Roosie - while you're on welding it up, take the rear bench out and look down at the sides of the floorpan - you'll see some oblong plastic covers...
Pull them out and have a good look inside - you'll be looking into the insides of the chassis rails. They ALL rust here sooner or later, mine looked mint from outside but were starting to rot slightly from the inside out
The Youth welded them up easy enough for me, but you really need the rear beam out to get at them to weld.
If all's good in there then get a good squirt of Dinitrol Cavity Wax in there
Neil.
PS on the plates you are going to weld for your MOT, make sure you don't block the drain slots up (you can see them in the bottom right of your pic) - This will have been where your rot started IMO...
Old Feb 11, 2007 | 08:19 PM
Roosie's Avatar
Roosie
cheers ill bear that in mind!
Old Feb 11, 2007 | 09:28 PM
COSSIE 1's Avatar
COSSIE 1
do u realise uve got 2wd rear badges on ur car mate?? 4wd ones will look so much better ...car looks nice btw
Old Feb 11, 2007 | 09:46 PM
ripper's Avatar
ripper
typical sierra repairs m8 good luck
Old Feb 11, 2007 | 09:52 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Depends if it's '89 or '90
Old Feb 11, 2007 | 09:53 PM
Alan s1's Avatar
Alan s1
As Neil S Has said i had to do mine Luckly for me i was @ a m8s workshop using his 2 poster removing the rear beam and noticed the rusted so cleaned it up and welded it whiles the beam was off
Does'nt look to bad tho sounded worse when you said it had Failed Badly on your other post
Fingers crossed Ps you see whot i mine by the wheel lines corsing more rusted got them out just in time But buy a cuple of cans of Under Seal Ł2/3 an can will be better then just Paint IMO
Old Feb 11, 2007 | 09:59 PM
Roosie's Avatar
Roosie
mines 1990 mate
must get some new rear badges then cheers
Old Feb 11, 2007 | 10:32 PM
Brian's Avatar
Brian
Looks good mate
Brian
Old Feb 11, 2007 | 10:37 PM
dave cos4x4's Avatar
dave cos4x4
not too bad really,should not be that hard to sort.
Old Feb 12, 2007 | 02:08 PM
Roosie's Avatar
Roosie
not much of a update but im getting used to this making brake pipe milaki!
im pleased with myself
Old Feb 12, 2007 | 03:23 PM
smitsturbo's Avatar
smitsturbo
well done good to see her getting fixed & not broken up
Old Feb 12, 2007 | 03:58 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Amen
Old Feb 12, 2007 | 09:07 PM
COSSIE CAL's Avatar
COSSIE CAL
whats the differ about 4x4 and 2wd badges?
Old Feb 12, 2007 | 09:27 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Strictly they're '88 to '89 and '90 to '92
The original ones were like this:
and the 90-92 ones were what I call 'plain', and the Sierra and RS were separate badges...I dare say someone can furnish us with a piccy...my collection doesn't appear to have one!
Old Feb 12, 2007 | 09:31 PM
Roosie's Avatar
Roosie
well my car rolled of production line in may1990
Old Feb 12, 2007 | 09:40 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Ah ha!!
Got one!!
It's of my mate's 4x4 Saff, hope he doesn't mind
Old Feb 12, 2007 | 09:43 PM
Roosie's Avatar
Roosie
must get one of them badges
Old Feb 13, 2007 | 12:11 PM
Roosie's Avatar
Roosie
welded a plate in place of cut out rust and then red oxide the inner wing not too pretty job but hey!
and now to check on the other side see what damage is there and too my suprise MINT no rust whatsoether and the plastic inner cover came of without breaking. so give it a good clean and added a bit of red oxide to that aswell.
get more on later today!
Old Feb 13, 2007 | 02:29 PM
Roosie's Avatar
Roosie
hammerite on aswell
looking good
Old Feb 14, 2007 | 08:23 AM
Roosie's Avatar
Roosie
will hopefully get my inner arch liners in today and sort out my gauges to go in
Old Feb 14, 2007 | 09:41 AM
Roosie's Avatar
Roosie
will be fitting some of these bad boys today
Oil pressure
Oil Temp
Boost
Voltmeter
AFR Gauge
Water Temp
Old Feb 14, 2007 | 10:37 AM
kennyken's Avatar
kennyken
Looking good roosie Will be back on the road pretty quick
Old Feb 14, 2007 | 12:23 PM
MattyRST's Avatar
MattyRST
It looks a really good job your doing well done keep the pics coming
Old Feb 14, 2007 | 03:21 PM
Roosie's Avatar
Roosie
fitted 2 gauges the paint kept chipping off the holder so i put permanent marker on the outside "i know it looks bad" im going to spray it again tommorrow!
Old Feb 14, 2007 | 04:00 PM
L33 BYT's Avatar
L33 BYT
Good work Stu.
This better spec that the one Pauline bought off ya?
Old Feb 14, 2007 | 04:16 PM
Roosie's Avatar
Roosie
why dont he pull his finger out?
Old Feb 14, 2007 | 04:21 PM
L33 BYT's Avatar
L33 BYT
He's put a load of cash into this house him and Nikki have bought.
Keep offering him cash for it but he's not interested
Old Feb 14, 2007 | 04:28 PM
KSA-Cossie's Avatar
KSA-Cossie
Looks like you're doing a great job on it m8.
Old Feb 14, 2007 | 04:44 PM
Nice one, soon be back on the road , and the rot caught before its too late
Old Feb 15, 2007 | 01:03 PM
Roosie's Avatar
Roosie
just fitted goodridge hoses and painted my caliper spent most of day collect my motocross bike after rebuild so didnt get a chance to do anything really
Old Feb 15, 2007 | 01:56 PM
L33 BYT's Avatar
L33 BYT
Old Feb 15, 2007 | 01:58 PM
L33 BYT's Avatar
L33 BYT
I so so want a cossie
Old Feb 16, 2007 | 09:58 PM
SS1's Avatar
SS1
in the end did the hoses fit through the holes..
or did you need to use cable ties as rs-nuts said to use ???
im gonna order a set for my car next week ...
oh and have you bled the brakes yet...???
i think they have to be done twice because of the abs
just pondering as you said you have flushed the whole system out of fluid
which is what i want to do and replace with dot 5 fluid
Old Feb 16, 2007 | 10:42 PM
Roosie's Avatar
Roosie
I drilled the hole out and made it 5mm bigger and it went right through then got a 15mm thin nut and got held in there properly, didint like the idea of using cable ties!
nah havent bled brakes yet
im changing mine to dot5 for track days
goodridge hoses make the brakes looks oo much better
Old Feb 16, 2007 | 11:00 PM
AJC's Avatar
AJC
well played mate
Old Feb 17, 2007 | 12:11 PM
Roosie's Avatar
Roosie
started on fronts today.
goodridge hoses on
cleaned calipers
and its polibushed all up front result
and this is how the car is looking at the moment
Old Feb 17, 2007 | 03:49 PM
Roosie's Avatar
Roosie
this might be the cause to my abs fault the sensor looks fooked
Old Feb 19, 2007 | 07:42 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Looks like the teeth have been at it
