ecu
Old Feb 10, 2007 | 07:23 AM
nick8saff's Avatar
nick8saff
Default ecu
how can i tell which ecu i have. im going for closed loop and need a l8 or p8 but i dont no the difference
Old Feb 10, 2007 | 07:49 AM
I think L8 were sierra and P8 were escos, best ask stu to be sure he will know.
Old Feb 10, 2007 | 09:59 AM
jon@work's Avatar
jon@work
The easiest way to distinguish between the early Weber-Marelli management systems is by the colour of the fuel mixture trim screw in the box. On the front face of the management box, where the large wiring loom plug fits, is a recessed hole, with a small plastic screw visible.
• The early hatchback systems have a yellow screw (L1);
• Four door cars have a white screw (L6). Also, the Weber-Marelli Level 6 systems have a mounting flange on their front face to fix them into the car.
• The Level 8 & P8 systems do not have a mounting flange; the sides of the box are smooth. Only the very early P8 systems were fitted with a mixture trim screw, but as an extra check, the Level 8 systems have a red or green sticker on one of the covers, this will have WD48.08 printed on it. P8 systems have a white sticker, and this will read IAW48/P8.
Old Feb 10, 2007 | 02:05 PM
Stu @ M Developments's Avatar
PassionFords Creator
As John says.
To elaborate slightly, only the 2wd 4 door cars were fitted with a Level 6. All the 4wd sierras were L8.
Old Feb 10, 2007 | 07:38 PM
nick8saff's Avatar
nick8saff
thanks just arnt sure what iv got
Old Feb 10, 2007 | 10:04 PM
Take a pic of the front and inside then pal and we will tell you.
Old Feb 22, 2007 | 04:25 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Also what is the difference between :
WD48.08/L3E-31 and WD48.08/L3H-34
They are both L8 ECUs I recon.
Old Feb 22, 2007 | 04:30 PM
One has catalyst friendly software inside and one does not.
Old Feb 22, 2007 | 04:35 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Yes, but both does have the red sticker isn't is ?
There are 3 L8 ECUs :
WD48.08/L3E-31 (red sticker)
WD48.08/L3H-34 (red sticker)
WD48.08/L3H-93 (green sticker for catalysed car)
So you mean that one of the 2 red sitckered ECU has a catalyst software inside it, but isn't used ?
Thank you for the explaination, Stu.
Old Feb 22, 2007 | 07:17 PM
Yes, one is catalyst friendly but it was never enabled and run due to no input, although ive seen teh same one running overseas with it active, so who knows, maybe a territory thing. The greentop strategy L3H93 was active in all territories.
Old Feb 23, 2007 | 04:26 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Ok, thank you Stu !
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
