ST brakes on s2 rst
Old Feb 9, 2007 | 06:30 PM
RSandy's Avatar
RSandy
Default ST brakes on s2 rst
ok, been offered calipers n discs n hoses off a fiesta st150
the calipers i know to be the same as the st170 focus, and i assume the discs are too
now i know iv seen s2's with these fitted upfront before, so what im after is a bit of info as to what brackets or fittings i need to get the calipers to fit etc etc
i have 17" wheels, so its not a problem. im assuming the fiesta st150 uses the same 300mm discs as the focus st170. if not, i wil just get st170 300mm discs anyways
any info appreciated
Old Feb 9, 2007 | 07:47 PM
DaveyBoyS1's Avatar
DaveyBoyS1
Im sure i'll be corrected if wrong but the st170 uses 300mm front brakes and im sure the st150's are smaller.
I have an st170 for the missus n must admit the brakes are fantastic
Dave.
Old Feb 9, 2007 | 11:01 PM
RSandy's Avatar
RSandy
ok, i think from what i can tell, the calipers are the same on the st fez and st170 focus, just the focus uses 300mm discs, and the fez uses 285mm.
i shal just buy 300mm anyways
but anybody know how to fit them?? do you need brackets specially made, or just washers to space the calipers as per cossie 4 pots??
Old Feb 10, 2007 | 07:17 PM
You could use 325 mm FRS discs instead under 17" with single piston caliper should go!!
A.t.p
Oct 23, 2015 07:54 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
