s2 rs holding back
Old Feb 9, 2007 | 05:10 PM
rs230's Avatar
rs230
Default s2 rs holding back
my s2 holds back but then if you back off then boot it again it will go like hell any one have any ideas
Old Feb 9, 2007 | 05:53 PM
Rick's Avatar
Rick
knock sensor is retarding the igntiion. CHeck the connector and tighten it up on the manifold. Also, try unscrewing it from the manifold, insulating it from noise, and tucking it away in the heater box. It MUST be electrically connected.
Old Feb 9, 2007 | 05:55 PM
Dragsteer's Avatar
Dragsteer
knock sensor on rst ?? you mean amal valve or what?
Old Feb 9, 2007 | 06:19 PM
Rick's Avatar
Rick
no, the knock sensor.
Old Feb 9, 2007 | 07:15 PM
nick series1's Avatar
nick series1
The rubber pipe from the airbox to the centre (suction) side of the turbo can collapse when it gets old. This strangles the turbo - grab this pipe and give it a squeeze - if it collapses easily then that'll be worth replacing. Get a samco on it.
Old Feb 9, 2007 | 07:32 PM
rs230's Avatar
rs230
i have been told to try the knock sensor i was told to unplug it so i did and still the same
Old Feb 9, 2007 | 08:28 PM
Dragsteer's Avatar
Dragsteer
where is knock sensor placed??
Old Feb 9, 2007 | 08:29 PM
nick series1
Does the car die - or just holding back like a missfire ??
The boost can blow out the spark.
Has this come on gradually ?? or just happened one day and now does it all the time ??
Old Feb 9, 2007 | 09:52 PM
Rick's Avatar
Rick
rs230
if u unplugged it and it drove the same, then it is defo the knock sensor.
Old Feb 11, 2007 | 10:58 AM
Dragsteer's Avatar
Dragsteer
Old Feb 11, 2007 | 12:47 PM
s2 ben's Avatar
s2 ben
right hand side of the inlet manifold green plug
Old Feb 11, 2007 | 08:41 PM
rs230's Avatar
rs230
yes its on the right hand side on the inlet mainifold and if i pull the pipe off the dump valve it will keep holding back then put the pipe back on and it will go fine. Then after a bit start to hold back again
Old Feb 11, 2007 | 08:44 PM
rs230's Avatar
rs230
its not a missfire just like a flat spot when its right it will spin no probs in 3 but when its playing up will hardly spin in second
Old Feb 11, 2007 | 09:05 PM
steven holland's Avatar
steven holland
i am having the same problems , just took mine out today for a run, it runs very sluggish in 1st and 2nd, it ticks over ok and revs up no problem, took it for a blast on the motorway and still seems to hold back. it did this last year, so stu at msd put on a second hand top boost hose on it , might have gone again ???
Old Feb 11, 2007 | 11:42 PM
SafeChav's Avatar
SafeChav
Such a common problem on MFI cars
Its also worth checking the operation of your TPS. My first RS had a similar symptom which was very noticeable in 5th, my TPS was intermittently faulty, seemed fine after i replaced it
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
imnoteasy
Aug 30, 2015 09:34 PM
YODI
Aug 30, 2015 01:12 PM
Marcus L
Aug 29, 2015 02:18 PM
Franko99
Aug 29, 2015 01:38 PM
