3DR boot lock
Old Feb 9, 2007 | 12:53 PM
Moonstone Kev's Avatar
Moonstone Kev
Default 3DR boot lock
The boot lock on our 3dr as stopped working with the central locking but it can still be locked & unlocked with the key, anybody got any ideas. Thanks
Old Feb 9, 2007 | 01:27 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
central locking motor not working on the boot seems logical to me
Old Feb 9, 2007 | 02:17 PM
Moonstone Kev
Would this be the same on a normal seirra ie 2.0gl
Old Feb 9, 2007 | 02:59 PM
antony215's Avatar
antony215
Escort Rs Turbo
Yep motor will be the same. Check the connections on yours tho they may just be a bit corroded and need a clean
Old Feb 9, 2007 | 04:10 PM
3 door does NOT HAVE MOTOR, it uses a solenoid, ie electrical plunger, same as xr4i.
I would firstr asscertain that you are getting a LOCK PULSE as they are succeptible to broken wires in tailgate, due to constant flexing opening and closin.
The solenoid looks like a drum about 1 1/2" in diametre and about 3/4" long with a little rod about 3/4 inches long attaching to the lock area, the solenoid is held onto a flat plate by boot lock, secured by the LARGE FLAT golden colour screws near lock.
Old Feb 9, 2007 | 04:31 PM
Moonstone Kev
thanks for the info Antony & Tabetha will check all the wiring 2moz
Old Feb 9, 2007 | 06:03 PM
Give us a shout if you need a replacement as I have two Mk1 sierras at mo, and 3/4 others , and "too many cars" she says!!
Old Feb 9, 2007 | 06:53 PM
Moonstone Kev
Will do Tabetha, thanks alot
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
