Fog light bulbs?
Old Feb 8, 2007 | 11:00 PM
User 32922's Avatar
User 32922
Default Fog light bulbs?
ok i've just bought the LHD reverse light so both match, where can i buy reb bulbs for it? and what type are the bulbs?
I found this site but i'm not sure what one to get
http://www.classic-car-accessories.c...log/BULBS.html
or
http://www.essexracing.com/index.php?cPath=34_67 (ones at the bottom)
Paul
Old Feb 8, 2007 | 11:21 PM
BillyCabrio's Avatar
BillyCabrio
The LED ones look pretty good, at least you won't have to change them
Old Feb 8, 2007 | 11:22 PM
User 32922's Avatar
User 32922
but theres 3 ....which one?
Old Feb 9, 2007 | 12:47 AM
NUTS RuS's Avatar
NUTS RuS
Lost me as reversing light bulbs should be white
Old Feb 9, 2007 | 06:12 AM
BA15S, bulb for 21watt clear medium envelope.
If you go onto www.norbsa02.freeuk.com you will see sokme brighter versions in HALOGEN, if you want these ?
Old Feb 9, 2007 | 12:46 PM
BillyCabrio
Its only a reversing light so it matches the other side of the car, it'll be used as a fog lamp tho Get it?
Old Feb 9, 2007 | 05:24 PM
rssteve's Avatar
rssteve
i put an led one in but the polarity of the cable was wrong so i cut it and swopped the wires over. You may be able to get an led one with the polarity the other way tho.
or just paint it with nail varnis, i mean when do you ever use your rear fogs?
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
