1 for the suspension guru`s (pick-up points)
Old Feb 8, 2007 | 03:04 PM
banhambuilt's Avatar
banhambuilt
Default 1 for the suspension guru`s (pick-up points)
the rear axle on the rs200 is off a 4x4 cosworth.
i have had to remove the ford standard shox brackets (on the rear of wishbone)as they were very close to the speedline alloys.
i have a set of group a bilstein coil-overs to fit,my question is:
what is the best angle to mount these?
do i fit them vertical,i will be making my own mounting points for the wishbones further inwards (about 20mm from stock location)
or would it be more effective to be pointing towards the front slightly (as the wishbone moves in a arc upwards)
thanks for your help
dave
Old Feb 8, 2007 | 11:01 PM
banhambuilt
can anyone shed a bit of light on this for me please
dave
Old Feb 9, 2007 | 10:37 AM
DAN P's Avatar
DAN P
would ask marco martin hadland or rainbird m8
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
