Conversion of Cvh/Zetec using a Rover Inlet???
Old Feb 6, 2007 | 01:52 PM
CosRush's Avatar
CosRush
Default Conversion of Cvh/Zetec using a Rover Inlet???
Anybody heard of this???
I was just reading about a setup using a rover inlet manifold which is supposed to be an upgrade on the original based on the fact the ports are much bigger and it a straight swap........
I happen to have a 620Turbo inlet with fuel rail..............
Old Feb 6, 2007 | 02:00 PM
JesseT's Avatar
JesseT
The oval ports of the manifold wouldn't match the CVH head's round ports very well. This manifold is often used with a zetec head though as it's a reasonable match in port shapes.
Old Feb 6, 2007 | 02:03 PM
CosRush's Avatar
CosRush
Thanks Jesse,
Perhaps somebody on here might be interested in it then
Old Feb 7, 2007 | 07:19 PM
chencho16000's Avatar
chencho16000
Default About inlet manifold from Rover.
I would like to see some photos, perhaps I´ll buy it.
Thanks.
Old Feb 7, 2007 | 07:20 PM
chencho16000
CosRush
Thanks.
Old Feb 7, 2007 | 09:08 PM
Red16's Avatar
Red16
i have one for the zetec turbo engine i was building
standard rover inlet from N/A M16 engine
top half of the rover manifold, new flange welded on to hold fiesta turbo throttle body
lower half of rover manifold being machined to remove the flange that mates to the head
after machining
zetec flange machined from a zetec inlet manifold
zetec flange welded to lower half of rover manifold
after machining the face to ensure a good seal with the head
rover fuel rail, drilled and tapped to accomodate the fiesta turbo fuel pressure regulator
the finished article, with fiesta turbo regulator, injectors, idle speed control valve and throttle body
quick fitment to the engine to see how it looked
Old Feb 7, 2007 | 09:24 PM
CosRush's Avatar
CosRush
Originally Posted by chencho16000
CosRush
Thanks.
You have PM
Old Feb 8, 2007 | 06:48 AM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
red i know u got the work done by a mate if i rember rightly or u done it at work ,
just wondering is poss how much to knock another 1 up ??
not overly in a rush ?
pm me if u can mate
thansk bri
Old Feb 8, 2007 | 07:55 AM
Red16's Avatar
Red16
beefy-rst-2 pm sent
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
AJC
Oct 1, 2015 06:47 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
