FAO Stuart Collins.....
Originally Posted by From Stuart's Siggy
JAMsport 1600 cvh
JAMsport tubular manifold
JAMsport head with standard valves
GT30 Turbo
44mm External Waste gate
gotech pro x management
2.5bar
400+bhp
100shot nos progressivly controlled
GT30 Turbo
2.5bar
400+bhp
Originally Posted by sas
Originally Posted by Tim
100 shot of nos would give 120-150 ish maybe without nos its not happening IMO.
S.
That was so funny went that went off!.
Originally Posted by Christian and Beccy
400+BHP??
So, when did that happen then??
You bringing it to our RR day??
400+BHP??
£600? a little??
400+BHP??
400+BHP??
i dont see why you keep digging @ Christian.
Its up to him what he spends his money on.
And lets be honest, The 1st hate post you done against him, was on his Management thread, and you was wrong then, so please drop it.
400+BHP??
Not this again, cunts!
Would be nice to see a reply from Stuart, can't see it making 400+ without NOS! Would be some acheivement if it does!
400+BHP??
400+BHP??
If i remember rightly not once did i call him anything, just point
out that possibly another reason his engine blew was because of det,
Then all the useal brown nosers popped up and started gettin lairy
400+BHP??
will do the numbers.
Matt, not taking anything anyway from Stuart and Jamie, but it takes ALOT more than time and effort to hit 400bhp from a 1600CVH.
I know that better than most. Remember that's a clear 50bhp more than mine and believe me we tried.
400+BHP??
Sorry, I'm not a mate of Christian's, and never meet him,
So i'm not butting in because of who he is, Just that you were wrong.
There are NO signs of Det on his engine, and if you knew what you was talking about, you would of too.
And it seems from how i read it, all you was trying to do is cause trouble.
If i'm wronge, sorry, but thats how it seemed.
In addition to what I just said above, I know that Stuart and Jamie have put time, effort and alot more into his car. I didn't want that to be taken as though time and effort is ALL they have put into it!!
Its the next step though, it was not long ago that people would laugh
at you for saying you were trying to squeeze 300bhp out of a 1600cvh
Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake!
I always thought say a 100 shot of nos gave you slightly less than 100?
ie 50 shot = approx 40ish hp, 100 shot = 80ish hp, and so on...
Can anyone confim the actual gains you get when using nos? Does it give the power it says on the tin? Or more? Less?
Paul
Paul
Paul
Paul
this is all achieveable with a wizard of nos kit not with one of the american brands.
Paul aka (Turbotrev)
There are so many benefits running nitrous on turbo charged cars especially for people who are into drag racing.
You might want to Consider nitrous not just because of the extra power nitrous can Generate nitrous is so Beneficial for turbo charged cars. Turbo cars are far safer on nos due to the cooling effect which prevent detonation
Nitrous its unbelieveable stuff, you could possibly drop a second on your ¼ mile times.
On gas i have no lag what’s so ever. Apart from more power, how would you like FULL BOOST at any RPM? Maximum power from the second you push the pedal? Because it totally removes all turbo lag - completely! Full power/boost from idle RPMs upwards! Stand on the gas and GO!
The nitrous initially provides the go, but this makes a lot of exhaust gas that spins the turbo up fast! Sudden boost too! Because if used as a "turbo lag remover" the nitrous is turned off as soon as boost is achieved via a manifold pressure switch, so the bottle lasts AGES! that’s if you wanted the nos for this Purpose (i didn’t) PEAK power can be drastically improved - if used normally (on all the time @ full throttle) rather than just to eliminate the turbo lag. charge cooling effect gives a measure of safety and prevents detonation, meaning higher turbo boost pressures can be used. and it also means a much bigger turbo can be used! with large turbos so much time is lost through lag after a gear change the turbo might take a second to spin up, this wont happen with nos. personally I think trying to run 2.4 bar and nitrous will cause him problems especially on a 8v head the engine will produce so much exhaust gases will be head be able to get rid of the cylinder gases before the next charge comes in maybe Stuart should do the testing before adding anything to his sig? would be good if he can achieve this because the car does look the part. just needs the times to back up his claims
On gas i have no lag what’s so ever. Apart from more power, how would you like FULL BOOST at any RPM? Maximum power from the second you push the pedal? Because it totally removes all turbo lag - completely! Full power/boost from idle RPMs upwards! Stand on the gas and GO! The nitrous initially provides the go, but this makes a lot of exhaust gas that spins the turbo up fast! Sudden boost too! Because if used as a "turbo lag remover" the nitrous is turned off as soon as boost is achieved via a manifold pressure switch, so the bottle lasts AGES! that’s if you wanted the nos for this Purpose (i didn’t) PEAK power can be drastically improved - if used normally (on all the time @ full throttle) rather than just to eliminate the turbo lag. charge cooling effect gives a measure of safety and prevents detonation, meaning higher turbo boost pressures can be used. and it also means a much bigger turbo can be used! with large turbos so much time is lost through lag after a gear change the turbo might take a second to spin up, this wont happen with nos. personally I think trying to run 2.4 bar and nitrous will cause him problems especially on a 8v head the engine will produce so much exhaust gases will be head be able to get rid of the cylinder gases before the next charge comes in maybe Stuart should do the testing before adding anything to his sig? would be good if he can achieve this because the car does look the part. just needs the times to back up his claims
turboboss , is your motor a zetec or a zvh mate ?
think i spoke to you before about importing some rods and pistons from the usa and u were giving me advice bout it bud
just wondering what block ur using , ist it a black top or a silver top ??
any suggestions on witch to go for ,
thanks bud
thanks bud
thanks bud
thanks bud
its a zvh form a silver top zetec if you are starting from scratch then go full zetec. it will work out cheaper then a properly built zvh only.
reason i went dowm the zvh route was because i spend so much moey on my cvh head. either black or silver top will do does'nt really matter which one, purchase your rods and pistons from the states steel rods and a set of pistons can be brought for under £500. even cosworth steel rods retail for £288
thanks
sean
yeah sean mate , got a girlfriend in the usa so hoping to either bring them home with me after a visit , or save some import duty buy having them sent home as a gift ,
rods a easy to get , but did u have ur pistons specced in the usa ? or did u buy them and have them machined to the correct c/r ??
just asking cos just looking at a piston rod combo on the us ebay and the c/r is for a n/a engine
any thoughs
thanks
p.s sorry for hiijacking the thread peeps
any thoughs
thanks
any thoughs
thanks
any thoughs
thanks
machining the chambers would cost you £180 i dont know off hand how much cc you would gain or just buy pistons with the correct c/r 9:0:1 alot of the ameicans call that low comp lol
