slow series 1....HELP!
Old Feb 4, 2007 | 06:46 PM
s1rststeve's Avatar
s1rststeve
Default slow series 1....HELP!
my series 1 is running like an old 1.1 fiesta, starts, idles and drives fine but when on boost its not responsive at all , after reading through other threads for hours on end i am fairly sure its running very lean due to faulty wiring to the charge air temp sensor or a faulty throttle position sensor? any ideas on how to test either of these or anything else it could be?
thanks in advance safechav!!!!
Old Feb 4, 2007 | 07:44 PM
Dragsteer's Avatar
Dragsteer
have you boost gauge? how much boost?
does your TPS click when you start to move throotle?
Old Feb 4, 2007 | 07:53 PM
smitsturbo's Avatar
smitsturbo
any smoke when you pull away or on boost
Old Feb 4, 2007 | 08:13 PM
s1rststeve's Avatar
s1rststeve
running just under a bar, holds it fine,
no smoke or rattles, turned on ignition and moved the throttle and it made a slight click, like a relay but quieter?
Old Feb 4, 2007 | 08:44 PM
Dragsteer's Avatar
Dragsteer
it must click with ignition turn on or off, no matter. did you opet throttle and pull throttle cable and see if click?
Old Feb 4, 2007 | 08:57 PM
s1rststeve's Avatar
s1rststeve
yeah like i said ignition on, ear to switch, open throttle, hear a click, like an electric switch or relay clicking on. is this right?
i thought it was but the more i look into this the more i realise i dont understand about the car i have owned for the past 4 yrs!
its really starting to annoy me as i dont wanna drive it for fear of killing it and there has been some nice cold sunny days lately!
Old Feb 5, 2007 | 01:10 AM
scotty86d's Avatar
scotty86d
take it to a tuner
Old Feb 5, 2007 | 08:40 AM
smitsturbo's Avatar
smitsturbo
maybe an air leek somewhere? check all jubalee clips etc. just a thaught
Old Feb 5, 2007 | 09:43 AM
s1rststeve's Avatar
s1rststeve
can anybody recomend anyone in the cambridge area to take it to?
Old Feb 5, 2007 | 03:43 PM
DazC's Avatar
DazC
SCS near Peterborough is probably the best/nearest place for you.
Sounds like you night have retarded ignition timing.
Old Feb 5, 2007 | 04:53 PM
SafeChav's Avatar
SafeChav
Before you take it anywhere i would be unplugging all the sensors and ecu's and having a continuity testing session to check for broken wires.
You can test the TPS with a multimeter its very easy to do.
Old Feb 5, 2007 | 06:17 PM
s1rststeve's Avatar
s1rststeve
any chance of telling me how to do this?
can borrow a multimeter from work, not too clued up with electrics!
do u think it could be a sensor problem then?
Old Feb 5, 2007 | 06:28 PM
SafeChav's Avatar
SafeChav
Sorry mate i meant to post up the diagram for the TPS.
As for the continuity testing, you'll need a wiring diagram and to unplug everything as ive said.
Old Feb 5, 2007 | 06:33 PM
s1rststeve's Avatar
s1rststeve
fair play , i notice that you have said in past threads thatr you have had trouble with this in the past?
what were the symptons?
Old Feb 5, 2007 | 06:41 PM
SafeChav's Avatar
SafeChav
For me changing the TPS made the difference, but i was new to RS's then and didn't really know what i was doing to be honest.
We did loads of stuff to it cos it was all cobbled up but i seemed to get the performance back when i changed the TPS.
The timing can also be a big influence on it i believe, MFI is pants
Old Feb 5, 2007 | 06:46 PM
s1rststeve's Avatar
s1rststeve
good mechanic friend done cambelt not so long back and re done timing, says its bang on.
problem started before timing was disturbed ,
any ideas if u can still get them from fords/
new one wouldnt hurt as i have changed loads of stuff trying to cure it!
Old Feb 5, 2007 | 06:49 PM
SafeChav's Avatar
SafeChav
Check the belt timing its so easy on a CVH
Was the dizzy played with at all?
You can still get them, when i was doing mine about 5 years ago i paid £40 odd for one, but then fixed the old one so i sold it on eBay.
Test it first though.
Old Feb 5, 2007 | 07:22 PM
s1rststeve's Avatar
s1rststeve
99% sure timing is ok.
had noticed a broken wire to charge air temp sensor and
thought that must be the cause but i have repaired it and
made no difference. timing is perfect on a timing light, that
good enough? got a vernier wheel fittd too.
Old Feb 5, 2007 | 08:29 PM
Dragsteer's Avatar
Dragsteer
tps is ok?
must be something with fuel then (?)
Old Feb 5, 2007 | 08:40 PM
s1rststeve's Avatar
s1rststeve
could be
i have changed the fuel pump and even managed to get a new fuelpump relay from fords ( £45!!! )
havent changed fuel filter tho so i guess it could be this also
got new hoses, solid top hose, even swapped the turbo as tis was smoking slightly,
still no joy
Old Feb 5, 2007 | 10:44 PM
////ANTHONY's Avatar
////ANTHONY
whats your timming set at? my charge air temp sensor isnt conected,will this effect anything? my amal valve is wired to a switch so i can use it as a 2 stage boost controler 6psi or 15psi
Old Feb 6, 2007 | 04:18 PM
s1rststeve's Avatar
s1rststeve
dunno mate, and does yours boost up and pull ok wiith sensor
not connected?
why isnt it connected anyway?
i thought it was like a safety in if your act gets too hot it
would cut the amount of fuel delivered to stop you cooking things?
or am i totally wrong yet again?
Old Feb 6, 2007 | 04:33 PM
s1rststeve's Avatar
s1rststeve
actually pretty sure timing is set at 12 degrees does this sound right?
piper cam , vernier wheel , felpro head gasket , turbosystems chip ,
k & n , stainless pipe, -31 , bar of boost and a pace radiator, so why
the funk am i being overtaken by mopeds?
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
