from what year escort is my dizzy? and is this the same one?
i have an escort turbo engine in my fiesta so im not 100% sure on the year of the dizzy.
and is this one below the same as my one above? just checking as i need a new one and want to make sure i get the correct one.
i think the numbers on it are
060 jh
0?87521019
89?f12100ha
the question marks are where i cant see the numbers very well as i only have a photo to hand at the min.
as for how to tell if your dizzy is working or not. if there is no spark and your fuel pump doesnt run (regardless of whether it primes or not) then its more than likely to be your dizzy.
if you still cant tell then i cut the signal wire and connected a wire to earth then dabbed the earth wire onto the signal wire going to teh ecu, this simulates the signal from teh dizzy and causes the coil to spark. the signal wire is the green/yellow one from the dizzy. hope that helps
060 jh
0?87521019
89?f12100ha
Originally Posted by fezzie2
next question, are they simple to fit, does anything need to be alligned or anything?
Dont need to remind you to take off dizzy leads 1 at a time when changing it or you'll get them out of the sequence they should be in.
Depending to Bosch's e-cat online:
MK3:
orig.: 0237521003
exchange part: 0986237651
MK4 -12/88
orig: 0237521003
MK4 01/89-
orig: 0237521019
exchange part: 0986237659
So you might have got a dizzy out of one of the last RST's
MK3:
orig.: 0237521003
MK4 -12/88
orig: 0237521003
MK4 01/89-
orig: 0237521019
steerfromdarear
28
Jan 29, 2016 06:14 PM
