How do you upgrade your msn messenger?
Just realised my msn messenger is the older version since i bought a new laptop i havn't upgraded it!
How do i get the latest version?
Cheers Spadge...
Cheers Spadge...
Originally Posted by AJ
I've still got the old one installed & it hasnt caused me any problems & i've been running 6.2 for a while now
I'll have a play with it tommorow when i'm less knackered
In that case just go to settings, control panel, add or remove & then uninstall the programme
Are you sure it hasnt uninstalled it automatically when you upgraded to 6.2? Im gonna check mine now too to see if it's still there lol.
Jules think what u got that is 4.7 is actually windows messenger not msn messenger, the messenger i think u talking about starts everytime u open outlook express
It lives in program files folder (c:\program files\messenger)with the name messenger NOT msn messenger which is a couple folders down, what i did with mine was just rename the msmsgs.exe file to something different so it dont auto run no more but will inform me if an update available on msn update, u could just delete the whole folder but recon everytime u check for updates it will say u need it, u can set it not to tell u about that anymore tho in update settings.(dont know anybody actually use windows messenger anyway anymore cause it not as good as msn messenger, dont do half the things, and dont ubderstand why microsoft run it along side msn, which is still after all microsoft init
Could be totally wrong about what your problem is but think that is what u after chap
Steve
.It lives in program files folder (c:\program files\messenger)with the name messenger NOT msn messenger which is a couple folders down, what i did with mine was just rename the msmsgs.exe file to something different so it dont auto run no more but will inform me if an update available on msn update, u could just delete the whole folder but recon everytime u check for updates it will say u need it, u can set it not to tell u about that anymore tho in update settings.(dont know anybody actually use windows messenger anyway anymore cause it not as good as msn messenger, dont do half the things, and dont ubderstand why microsoft run it along side msn, which is still after all microsoft init
Steve
This can happen when you upgrade Messenger sometimes.
As you said, you can't uninstall the old version using Add/Remove programs because it's not in the list
I use a script to remove the old Messenger, you just run it, reboot and the old version is gone
I can send you it if you like?
cheers, Alan
cheers, Alan
