last of my cosworth parts - must go
Old Feb 3, 2007 | 05:14 PM
les3002's Avatar
les3002
Default last of my cosworth parts - must go
any item can be posted at buyers cost.
standard 2wd saph exhaust + downpipe (minus backbox) £20
fuel filler flap £2
alternator bracket £2
steering coloum control surround (ignition switch, indicators, bonnet pull) £2
engine block 205 £free (cracked in oil way)
oil cooler £10
inlet manifold, plenum, plenum elbow. £30
2 x alloy engine mounting arms £10
both mirrors and backing plates £5
1 front hub inc abs sensor £10
dash + 99% of interior plastics £20
ecu cover (has hole for gauge) £2
samco turbo inlet pipe £5
samco intercooler to throttle pipe (with t piece for d/v) £10
bootlid £15
bonnet £20
2 x rear central locking motors £5 each
both headlights £15
2 x head light washer mechanism £10
washer motor £2
fuel rail £10
std turbo to intercooler hose £5
front arb £10
rear arb £10
abs ecu £5
downpipe £10
lamp failure ecu £2
steering coloum shaft plus other bits £5
2 x clear front indicators £5
fuel pump bracket £5
front subframe £10
2 x front arms £10 each
pas rack £20
pas pump £10
pas bottle £5
std map sensor plus pipe £10
radiator £10
Old Feb 3, 2007 | 06:27 PM
garyrs's Avatar
garyrs
hi there, were is st helens, do you no what side the hub is, and is it 2 or 4 wheel drive do the side skirts have jack covers, and what color is the rear bumper, cheeers gary, garydivney05@aol.com
Old Feb 3, 2007 | 06:47 PM
fiestasi1800's Avatar
fiestasi1800
What condition is the rad in?
Old Feb 3, 2007 | 07:18 PM
LUKE2711's Avatar
LUKE2711
pm sent
Old Feb 4, 2007 | 08:36 AM
les3002's Avatar
les3002
st helens is in merseyside mate.
cant remember what side the hub is but i could have a look, its 2wd, the skirts have 1 maybe 2 covers with them and the rear bumper is white.
the radiator ideally needs a recore.
Old Feb 4, 2007 | 09:43 AM
garyrs's Avatar
garyrs
i would like some of these parts , but as i am in dorset its a bit far cheers for the reply thou, gary
Old Feb 4, 2007 | 10:11 AM
Rippers's Avatar
Rippers
Monte Geek
Default Re: last of my cosworth parts - must go
Originally Posted by les3002
rear beam £20
Assuming this is 2wd how much posted please
Old Feb 4, 2007 | 12:18 PM
cameron2's Avatar
cameron2
Have you got the 2 rear metal 'u' straps that hold the arb on to the floor?
Pm me a price pls.
Old Feb 4, 2007 | 05:16 PM
les3002's Avatar
les3002
cameron: i dont think so mate will let you know if i find them though.
paul: your probably looking at around £20 to post the rear beam.
Old Feb 4, 2007 | 07:06 PM
BRI308's Avatar
BRI308
Default BUMPERS
DO YOU STILL HAVE THE BUMPERS ,WOULD YOU BE ABLE TO POST THESE? THANKS BRIAN
Old Feb 4, 2007 | 07:13 PM
Rippers's Avatar
Rippers
Monte Geek
Paul: your probably looking at around £20 to post the rear beam.
I'll have it mate how do you want paying
Old Feb 4, 2007 | 08:38 PM
The DIVA's Avatar
The DIVA
Les......You got any 2wd rear hubs and shafts ?
Old Feb 5, 2007 | 01:53 AM
janvanv's Avatar
janvanv
www.rallyanarchy.com
Hi, I need to get this week some of your parts, can you say if you still have them?
2 rods---assuming they're not blown up junk
flywheel
2wd intercooler
alternator
amp
Clutch---pressure plate I hope
Kidney box
coil
And do you maybe have the water-pump pulley?
Thanks!
John
Old Feb 5, 2007 | 05:05 AM
dox's Avatar
dox
u have pm
Old Feb 5, 2007 | 12:33 PM
les3002's Avatar
les3002
brian - sorry mate bumpers collection only due to size.
paul - sounds good mate my paypal is les3002@hotmail.com.
diva - ive got the rear hubs mate still in the arms, shafts are gone though.
jan - ive sent you a message back
dox - replyed.
Old Feb 6, 2007 | 04:21 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
hi how much for the tailgate delivered? is it good?also if you have the strip that goes under the headlights. or where are you, will pick up if close cheers
Old Feb 6, 2007 | 05:31 PM
dazzle740's Avatar
dazzle740
hi there mate
What colour is the dash?
Old Feb 7, 2007 | 09:03 AM
les3002's Avatar
les3002
the tailgate is in decent condition, dont know if i can post it though but im only down the m6 near wigan, im also going to blackpool at some point today so if your quick i could drop it off.
unfortunatly the headlight strip is no good.
also the dash is grey.
les.
Old Feb 7, 2007 | 10:57 AM
RSCossieGaz's Avatar
RSCossieGaz
what condition is the flywheel is it 2wd?
Old Feb 7, 2007 | 02:15 PM
les3002's Avatar
les3002
flywheel sold today mate sorry
Old Feb 7, 2007 | 02:23 PM
RSCossieGaz
no worries mate
Old Feb 12, 2007 | 09:35 AM
les3002's Avatar
les3002
bttt
Old Feb 23, 2007 | 10:06 AM
les3002's Avatar
les3002
UPDATED
Old Feb 23, 2007 | 02:54 PM
philalmit's Avatar
philalmit
are the rocker cover and inlet manifold sold separatly? If so how much?
Cheers Phil
Old Feb 24, 2007 | 10:10 AM
les3002's Avatar
les3002
hi, the rocker cover is sold and id like £50 for the inlet manifold.
Old Mar 2, 2007 | 10:49 PM
82insecond's Avatar
82insecond
how much for the spoiler posted bud ??
Old Mar 3, 2007 | 12:20 PM
stevieturbo's Avatar
stevieturbo
C**t
What condition are the rear arms in ? Are they rusty ?
Cheers, Stevie
Old Mar 6, 2007 | 01:41 PM
les3002's Avatar
les3002
82: 30 for the spoiler posted mate
stevie: they are in decent condition, can supply pics if you like.
Old Mar 6, 2007 | 05:08 PM
stevieturbo
C**t
Please do....although postage might be awkward.....
Old Mar 6, 2007 | 06:34 PM
les3002's Avatar
les3002
i could send them as two packages so would probably be around the £20-£25 range although im not sure if you being from ireland might make it more?
if you want some pics though ill try and sort some out tomorrow.
les.
Old Mar 6, 2007 | 07:52 PM
stevieturbo
C**t
Pics would help...current arms are ok, but quite rusty around the ARB bracket.
Plus I was going to be getting some poly bushes anyway. Might be able to kill 2 birds with one stone here.
Old May 5, 2007 | 05:27 PM
les3002's Avatar
les3002
new list
Old May 7, 2007 | 05:47 PM
Noz's Avatar
Noz
I'll take the turbo oil feed pipe matey
Old May 7, 2007 | 08:04 PM
mattajturners's Avatar
mattajturners
How much for these 2 items delivered!!!
1...steering coloum control surround (ignition switch, indicators, bonnet pull) £5
2...2 x alloy engine mounting arms £10
Do you have paypal? please PM me..
Thanks
Old May 8, 2007 | 05:03 PM
les3002's Avatar
les3002
pm'd
Old May 18, 2007 | 03:41 AM
Noz's Avatar
Noz
Oil feed pipe received, cheers
Old May 22, 2007 | 04:51 PM
les3002's Avatar
les3002
np mate
Old Jun 30, 2007 | 10:10 AM
les3002's Avatar
les3002
bump offers?? going the tip soon
Old Jun 30, 2007 | 10:58 AM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Whats the dash like mate? any holes or big scrapes?
If you have a chance do you think you could send me a couple of pics ?
cheers
Old Jul 4, 2007 | 02:49 PM
I8A4RE's Avatar
I8A4RE
How much for the rear jacking covers?
