torque setting, water pump
Old Feb 3, 2007 | 01:25 PM
////ANTHONY's Avatar
////ANTHONY
Default torque setting, water pump
my water pump is ratling , anyone know the torque settings for the new one ive got, i think its 10 lb but not sure
Old Feb 3, 2007 | 01:34 PM
fast_ford_uk's Avatar
fast_ford_uk
cant see one in the book, do them tight but remember ther only small 10mm's and easily shear off
Old Feb 3, 2007 | 04:47 PM
Craigb's Avatar
Craigb
Its around 8-10 lb if i remeber correctly.
Old Feb 3, 2007 | 05:01 PM
SafeChav's Avatar
SafeChav
On a CVH?
I've never used a torque wrench, use a 1/4" drive ratchet, then you can get them tight but its VERY hard to shear them off
Old Feb 3, 2007 | 05:20 PM
Craigb's Avatar
Craigb
Id be more worried about stipping the aluminuim threads then snapping the head off the bolt.
SafeChav's Avatar
SafeChav
Aluminium threads?! on...........?
Old Feb 3, 2007 | 05:27 PM
Craigb's Avatar
Craigb
Ah, Fook. Got all mixed up for a minute there Ermm ignore the above post please.
Old Feb 3, 2007 | 05:29 PM
SafeChav's Avatar
SafeChav
If i had a torque wrench that did torques that low i would use it, but seeing as i dont i always use the smallest ratchet possible and have never had a problem or any leaks
Old Feb 3, 2007 | 05:32 PM
Craigb's Avatar
Craigb
Also the haynes manual says 8-11 lb for the oil pump but I cant see the water pump torque. As they are both 6mm's (IIRC) then both should be of similar settings. Like safechav says a bit of common sense when doing them by hand and you cant go wrong.
j.hammond1
30
Oct 31, 2021 05:28 PM
FlashRS
Aug 30, 2015 08:07 PM
cameron2
Aug 25, 2015 07:18 AM
Steve Escos
Aug 24, 2015 07:56 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
