im not getting any fuel past the metering unit -------HELP
Old Feb 1, 2007 | 05:42 PM
fast_ford_uk's Avatar
fast_ford_uk
Default im not getting any fuel past the metering unit -------HELP
i have a decent fuel pressure up to the metering unit but no pressure after or fuel in the injector pipes etc, i got the car to start by pushing down the plunger slightly, so i adjusted it down but the car still wont start, could it be an air leak of sum kind?
anyone else had this prob or no what it is
thanks in advance
Old Feb 1, 2007 | 06:08 PM
rstben's Avatar
rstben
Default unit
hi m8 have u had the top off it coz there have a black rubber joint in them think it mite be a diaphram of sum sort and it cud be split and losing pressure
Old Feb 1, 2007 | 06:10 PM
fast_ford_uk
u mean the metal cassing with 3 star drive bolts?
Old Feb 1, 2007 | 06:17 PM
rstben's Avatar
rstben
Default unit
ye thats the 1 its got 4 i think just be careful coz u can round the heads of
very easy like i did.also try turning the car over and pushing the air valve down manualy on the unit i got a flame out of myn b4 but it did start after i dun that
Old Feb 1, 2007 | 06:28 PM
fast_ford_uk
yeh it started first time so i adjusted it but know it wont start again
Old Feb 1, 2007 | 06:36 PM
rstben's Avatar
rstben
Default unit
theres a black plug on one of the sides off the unit there always fcuk up so try taking it off bit of wd in there and try again,its got to be sumting silly but just finding out what
Old Feb 1, 2007 | 06:41 PM
SafeChav's Avatar
SafeChav
You may have air trapped in the metering head mate
Crack the bolts off the top and crank it over until fuel pisses out!
Old Feb 1, 2007 | 06:46 PM
fast_ford_uk
u mean the bottom of the injector pipes or the actual bolts for the metering head, ive tryed the pipes
Old Feb 1, 2007 | 06:48 PM
SafeChav's Avatar
SafeChav
The banjo fittings on the pipes.
Old Feb 1, 2007 | 07:00 PM
fast_ford_uk
done, thers no pressure were cracking one off i mean cracking it over
Old Feb 1, 2007 | 07:07 PM
rstben's Avatar
rstben
Default car
just cn ur other post there with the head off if just done the same thing head and wen it was all boxed u and ready to try i had the same problems wudnt start so i done all them things iv said and i also cracked of the fuel lines at the top of the unit turnd it over and waited for the fuel to cum out my b try that and if it still dont work m8 u mite have 2 get sum 1 out to have a look,just go round ur full enging bay and make sure every thing is on rite i.e sensors fuel filter fuses wires
gud luk m8 hope its nothing big
Old Feb 1, 2007 | 07:22 PM
fast_ford_uk
Default Re: car
cheeRS mate but as im a mechanic i cant really call any one out lol, i will get it solved just a matter of time and maybe ŁŁŁ
Old Feb 1, 2007 | 08:39 PM
PaulT's Avatar
PaulT
I normally crank the engine over and hold down the plunger and this normally does the trick but if you have had it to bits then who knows
PaulT
Old Feb 1, 2007 | 08:46 PM
gup's Avatar
gup
if you push the plunger down does it go down smoothly or rough
if you push the plunger down when starting does it start and run
also when pushing down can you feel any resistance in the flap itself
Old Feb 1, 2007 | 09:05 PM
fast_ford_uk
plunger feels smooth and thers enough clearence to the bore etc
the car did start first when the plunger was down but now it hasnt made a difference, the metering unit had a puddle of fuel at the bottom, thats been cleaned up now and thers no sign of any leaks
Old Feb 1, 2007 | 09:06 PM
fast_ford_uk
when it does fire its a strugle to keep it idleing
Old Feb 1, 2007 | 09:31 PM
gup's Avatar
gup
the plugs are prob wet fella disconnect the cold start valve and clean the plugs up
you did jet wash the engine it might have some water in the boost pipes or the air filter is wet
does sound like the a/f meter is at fault
check that your oil is not mixing with petrol too fella
Old Feb 2, 2007 | 12:24 AM
SafeChav's Avatar
SafeChav
If you've got fuel in the bottom of the metering unit box then the metering unitself has probabl gone!
Quite a common thing
Old Feb 3, 2007 | 02:01 AM
fast_ford_uk
i stripped it today and ther was loads of shit inside cleaned but still no joy, it fired once but then not again, wheres the best place for a metering unit, ebay? thanks
Old Feb 3, 2007 | 08:28 AM
gup's Avatar
gup
pm sent matey
Old Feb 3, 2007 | 04:53 PM
SafeChav's Avatar
SafeChav
Are you getting fuel trickling out of the metering unit?
155lee
Oct 27, 2015 04:55 AM
Flateric_2002
Sep 15, 2015 08:41 AM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
