Fitting of an RS 500 Intercooler for an Escort Cosworth T34
Old Feb 1, 2007 | 04:47 PM
Mondleo's Avatar
Mondleo
Default Fitting of an RS 500 Intercooler for an Escort Cosworth T34
Does anyone have any instructions on how to fit an RS 500 style Intercooler to a 1992 K reg Big Turbo Escort Cosowrth.??
If they have an adobe acribat instruction can they pm me or email me it please.??
Ta..
Old Feb 3, 2007 | 10:29 AM
DENNIS's Avatar
DENNIS
i don't know of any " instructions " but you will need to remove the rad, hoses and the old intercooler. you will need a charge cooler bypass hose ( try samco or rouse ) with that lot out of the way you need the fittings ( same as the rad mounts , bolt, spacer & bushes ) the cooler will then " just " bolt to the body ( just before the rad mount ( the raised part ) there should be two captive nuts ).
you may need to " mod " the front cross panel to fit pending on the cooler...
refit the rad and hoses, job`s a good`n
best of luck.......
Old ford
Jul 31, 2015 06:50 AM
