rear bushes
Old Jan 30, 2007 | 05:49 PM
THE RADMAN's Avatar
THE RADMAN
Default rear bushes
what are the rear trailing arm bushes like to change? the ones that bolt to the bodywork just in front of the rear wheels,is it a major job or not too bad?
Old Jan 30, 2007 | 08:07 PM
FRS 3409's Avatar
FRS 3409
not a major headache just a little time consuming. all straightforward going to get at the bolts needed undone to drop everything down then start attacking the old bushes with blowtorch, drill, hacksaw.
all in all give yourself 4 hours to complete the job. may as well change the rear anti roll bar bushes for uprated items while your under there
Old Jan 30, 2007 | 10:24 PM
THE RADMAN's Avatar
THE RADMAN
cheers theres no way of doing it in situ then? just levering the arm down or anything?
Old Jan 31, 2007 | 12:45 AM
FRS 3409's Avatar
FRS 3409
theres not massive amounts of movement to allow you to lever them down very far. even if you could it makes it a little awkward to attack the old bushes and press the new ones in as the arms will wave about!
ian
rex647
Mar 6, 2022 06:20 AM
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
