PLEASE DELETE WHEN YOU HAVE THE TIME
Yes my last Cosworth i will ever own is being ripped apart,alot of the goodies already sold
like complete engine,intercooler,rad,ecu,front brakes!!!!!
I will be very honest.
F reg....magenta...2wd Saff
The main part i wish to sell is a fully rolling shell it will be complete bar engine and all ancillaries under the bonnet (although i have std parts to go with it cheap like coolant tank std rad inlets etc etc) also no front brakes or ECU.So basically you get:-
Shell,which is very very good NO RUST
..everyone who see it is blown away with the condition,no dents
..there is however a flaw on the bit next to rear door pillar the primer has reacted under the paint and brought out a minor case of chicken pox
...Not major and would be nothing major to repair...you will struggle to find a shell and underneath this solid BELIEVE ME...comes with morrettes too...a little stone chipping on the front too..but only minor....this car shines cleaned up it looks brand new
Gearbox...recently rebuilt by gearboxman so mint
Rear diff...perfect no noises
Full koni suspension
Std rear brakes
17in TSW wheels NEW not to manys taste but i like em
...shod with 215's up front and 235's out back
Grp A fuel pump installed
Complete custom interior with half leather and alacantra this really smells of leather inside not like your normal cossie
..door cards rear shelf kick panals all leather custom and its MINT
ICE is fantastic mega sounds
the whole boot has a custom install 2 big subs 2 big amps 6 disc CD changer,playstation 2......it has alpine head units 3 tv's (2 in rear head rests) its mental
This is a very special car indeed and you would only need to spend i reckon about 1500 to get it fully operational
I want £3250 which i feel is justified considering i have sold the same as this before which was manky with rust and std interior nothing special for 1600!!!...So you work it out...spend 1.5k on it and you will have a car thats worth ALOT more!!!!
Pictures i can only show you pictures from when rhys had it as my computer crashed and i lost all mine..oh it has a rouse front splitter now...no longer has those wheels either:
TO ADD ITS STD RIDE HEIGHT NOW!
I bought these for my cars cheap....they are Lucas ones and work very well.
1 x ACT sensors
1 x Crank sensors
£10.00 EACH + Post which will be £2.00
Edited due to sale...be quick!
as bought from Mike Rainbird in the light blue variety About 200 miles only ...£70.00 delivered
3BAR map sensor....£40.00 delivered
2wd 170MPH clocks a couple of screws missing from the cover bit and the white dials are faded yellowish but it all matches LOL....£15.00
2wd rad with fans no leaks £85.00
4x4 header tank no cracks with free cap ...£35.00
Oil pressure gauge no sensor with water temp gauge with sensor and fitting kit (they light up when ignition is on cheap make lol but look good ) in a carbon fibre mounting to replace your vents....£40.00
2wd exhaust manifold both parts no picture needed...£35.00
like complete engine,intercooler,rad,ecu,front brakes!!!!! F reg....magenta...2wd Saff
..there is however a flaw on the bit next to rear door pillar the primer has reacted under the paint and brought out a minor case of chicken pox Gearbox...recently rebuilt by gearboxman so mint
Std rear brakes
...shod with 215's up front and 235's out backGrp A fuel pump installed
the whole boot has a custom install 2 big subs 2 big amps 6 disc CD changer,playstation 2......it has alpine head units 3 tv's (2 in rear head rests) its mental This is a very special car indeed and you would only need to spend i reckon about 1500 to get it fully operational
1 x ACT sensors
1 x Crank sensors
Originally Posted by JonnyBravo
How much for the gearbox Phil ? if its going seperate that is
I saw this car a few days ago and for what youre getting for £3250.00 is amazing!!
An absolute bargain this, as Phil says £1500 for an engine and you have a very cheap Saff which is in mint condition.
Interior is absolutely fantastic.
Good luck with the sale Phil, not that youre going to need it as this is gonna fly.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
