zvh query
im getting a 1.8 bottom end converted to run a cvh head. going to wack on my mfi head but how do i sort the pipes at the back for water going into the water cooler.
the block im after
the block im after
that water cooler unscrews, but i have heard off them blocking, perhaps youd be better fitting a proper mocal oil cooler and then you would be putting less strain on the water radiator
