turbonator
If its what I think it is it a stupid bit of plasic that goes in the pipe from your air filter
Did fuck all more to my mates car than "possibly" fuck his air flow sensor. (well it failed not long after fitting one of them things)
its some kind of fan that goes inside your induction hose akter your air filter it is ment to improve air speed and is ment to give you up to 35 bhp more and better fuel cosumption
Make sure you get one of these as well. http://cgi.ebay.co.uk/Job-Lot-50-Mod...QQcmdZViewItem
I think that plus the turbonator will give you a good +50bhp easy!
Originally Posted by Alps Pacino
89XR2
I have 2 of them i have a resistor feeding a resistor for maximum resistance
pmsl
We testing a very big and seemingly powerful (created a hell of a wind) electric supercharger on the rolling road and with datron gear, and it did NOTHING.
So what chance does something thats not powered by anything have
89XR2
The only problem with the roof scoops is that what you gain in bhp you loose in aerodynamics
well people i asked if any one had bought and tried one and what gains if any,just for some idea of what it was about, but come on ere is no need for at
Alps Pacino
sounds like your sorted with that then, ive got a variable resistor sitting here if you want it. gives you 13 stages of boost pressure from the turbonator. you really need this to make the most of it.... apparently with this and the dual resistance and turbo capacitor you have, you should see gains of about 150 bhp any day
rigwrecker
Were trying to pt humour into a situation that isnt funny, the situation being that you have wasted ŁŁŁ on something thats known to be about as usefull as jackie goodies left arm
cheers lad someone wi a nice bone in there body.where a come from ere is not a lot of people that will carry out performance enjine work and the nearest rollin road is 4 hours away so any simple cheap mods is all a will take on
