abs removal?
Old Jan 21, 2007 | 09:38 AM
mk4gartrac's Avatar
mk4gartrac
Default abs removal?
I am looking to remove the abs system from my car as the car dose note require it and it dose not work anyway can i just unplug the units and remove the controll valve unit and just connect the brake pipe together or am i looking at replacing the hole system ?
Old Jan 21, 2007 | 09:41 AM
mk4gartrac's Avatar
mk4gartrac
forgot to mention im running sierra cosworth 4x4 running gear and braking system
Old Jan 22, 2007 | 05:29 AM
mk4gartrac's Avatar
mk4gartrac
Please anyone? i need to get this sorted asap
Old Jan 24, 2007 | 06:03 PM
You need to remove all the the system as the pressure from m/cylinder is not regulated anymore and it will lock up very easily, just use a non servo m/cyl from another car, then remove abs system.
Old Jan 24, 2007 | 08:07 PM
mk4gartrac's Avatar
mk4gartrac
Am thinking of replacing the mastercylinder with twin mastercylinders and bias box looks like a good setup
Old Jan 25, 2007 | 10:48 AM
No problem then all sorted.
Old Jan 26, 2007 | 10:03 PM
mk4gartrac's Avatar
mk4gartrac
so what do i do with the electrics?
Old Jan 27, 2007 | 04:16 PM
Just remove any fuses, no need to take out masses of wire unless you want to, will not affect car anyway.
Old Jan 27, 2007 | 09:38 PM
mk4gartrac's Avatar
mk4gartrac
sweet cheers mate il get on it asap
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
