CLIFFORD ALARM HELP NEED PLZ!!!!!
As above
my dad went to start tthe cossie today and the battery was a bit flat so he charged it for a hour or so started the car opened the bonnet shut the drivers door and it all locked up
i no a few people this has happen to but some times the car has been left runnin 4 30mins etc... in the gargae and never done it is it because the battery was a little flat or is it like on a timer etc... or wat make it happen
lucky the bonnet was open this time and was able to turn car off etc... any help wud be great as dont want this to happen again
i no a few people this has happen to but some times the car has been left runnin 4 30mins etc... in the gargae and never done it is it because the battery was a little flat or is it like on a timer etc... or wat make it happen lucky the bonnet was open this time and was able to turn car off etc... any help wud be great as dont want this to happen again
Originally Posted by BigMouthBillyBass
this'll fix it
my dad rang me up telling me he said thats the window is goin in i said na just bent the door and a coat hanger done the job wif out the mess
Originally Posted by avid-fan
engine rpm is 2000 revs
all doors will lock
did he rev it up from under the bonnet
all doors will lock
cheers mate
S2
imm guessing his keys where in the car when the full closure started...
heres a tip i always leave my driver side door window half open just incase..
when the car is running
S2
Leaving windows open is an open invitation!
RST
ah so you have the full closure option
do you have the anti hijackblakjax mod
fooking awesome gizmo that
RST
its a code password system... you have to type a code into the the dash switch
after the car hit over 2000 revs if not typed in
a 30 second count down starts
at first your brake lights start flashing then the indicators as well ...
then the engine dies FULL STOP
car will not start until the code is entered into the touch panel
also if car is running and a door is opened the count down starts again ..
so if some body jacks you at lights ..with a knife or a gun ...
you just get out of the car ..and it will be found about half a mile away
hopefull not wrapped around a lamp post
well worth getting if you have a clifford alarm
http://www.clifford.com/g5/access/default.asp
not sure on the price and you carnt fit it yourself
because it voids the fitting paperwork
Thanks Son for asking (RST)
Thanks for the advice
Cor what a night mare that was
I went out to the garage for something because im doing work in doors looked at the car and i thought ill give it a start up aint been started in weeks
Then it was like me Son says started after a little charge closed the door as normal walked round to the engine bay next thing i know i cant get in to it
Thught i need this today glad i spoke to my son first because i would have done the window
The alarm is a Clifford 650
I went out to the garage for something because im doing work in doors looked at the car and i thought ill give it a start up aint been started in weeks Then it was like me Son says started after a little charge closed the door as normal walked round to the engine bay next thing i know i cant get in to it
with the the black jax added on
but you have the window closure add on as well
is - http://en.wikipedia.org/wiki/Blaster_(flamethrower) - Thatcham approved?
Thinking about getting one on my Focus, just in case i have to work in Chapeltown again
(ARGHHH hotlink doesnt work...cut and paste im afraid, must be the _ )
