RS Turbo questions
Old Jan 20, 2007 | 01:13 PM
Billy_RS's Avatar
Billy_RS
Default RS Turbo questions
How do you take the front suspension off?
How do you get the rear quarter windows out without smashing them?
Thanks
Old Jan 20, 2007 | 02:07 PM
M K's Avatar
M K
Default Re: RS Turbo questions
Thanks
both pretty straight forward fella when you look at it,
but get a haynes manual and it will give you step by step instuctions
Old Jan 20, 2007 | 02:08 PM
addiction's Avatar
addiction
if you mean the front struts then,remove fexi from its guide,undo pinch bolt,tap the hub downwards with a hammer until it drops off,undo top mount,remove strut!!
lay on rear seats,put your feet against the glass and push hard!!
Old Jan 20, 2007 | 05:22 PM
Billy_RS's Avatar
Billy_RS
Ok, Thanks
Old Jan 22, 2007 | 04:08 AM
thelynx's Avatar
thelynx
Had to cut the rubbers to get mine out
Old Jan 22, 2007 | 10:23 PM
NICK321RS's Avatar
NICK321RS
go in the back of your car get a flat end screwdriver push the rubber in under the window frame all the way round and window should release
therefor u wont have to cut the rubber
Old Jan 22, 2007 | 11:35 PM
SafeChav's Avatar
SafeChav
Trust you to come up with a rough ass method like that...........
You forgot to say he will need his glamorous assistant outside to catch the glass (he said WITHOUT breaking )
Matt Baxter
Sep 16, 2015 08:30 PM
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
