Temp Sensor XR3i???
Old Jan 20, 2007 | 11:23 AM
hutchyotb's Avatar
hutchyotb
Default Temp Sensor XR3i???
where bouts is the temp sensor found on 1.8 16v engine? got the part today but not sure its right
Old Jan 20, 2007 | 01:12 PM
tim10_10's Avatar
tim10_10
Temperature gausge sensor or ecu temp sensor? If its the gauge one its under the thermostat housing at a diagonal angle.
Old Jan 20, 2007 | 02:20 PM
slickescort1981's Avatar
slickescort1981
theres a temp sensor in the top right hose on the rad, should be pointing towards the gearbox.
Old Jan 20, 2007 | 07:12 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thats thr fan switch thats in the top hose mate
coolant temp sensor for ecu is the top 1 on thermostat housing and the 1 at bott of housing is the sender for the temp gauge on dash
hope this helps
Old Jan 20, 2007 | 07:14 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
hope this helps
Old Jan 21, 2007 | 10:10 AM
slickescort1981
good point soz!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
