help knocking noise IS THIS SERIOUS
Old Jan 19, 2007 | 04:59 PM
steveo135's Avatar
steveo135
Default help knocking noise IS THIS SERIOUS
got a really loud knocking noise coming from the rear end of my 2wd saff. started when turning now does it all the time under throttle in a straight line, definatly from the rear of the car...help.
NOW WHEN DRIVING FEELS LIKE A HAVE A PUNCTURE
cheers
Steve
Old Jan 19, 2007 | 05:13 PM
SafeChav's Avatar
SafeChav
Probably damaged the crown wheel on the diff or something like that
Old Jan 20, 2007 | 10:59 PM
bortaf's Avatar
bortaf
check the wheel nuts
Old Jan 21, 2007 | 09:55 AM
mk4gartrac's Avatar
mk4gartrac
Thought my diff had gone turned out the wheel nuts on 1 side were loose and i had the same on the front a slight knocking when turning then all the time and that turned out to be a warped brake disc.
Old Jan 21, 2007 | 11:43 AM
SafeChav's Avatar
SafeChav
Old Jan 21, 2007 | 01:50 PM
Alvyn's Avatar
Alvyn
also check the rear prop bolts and also the drive shaft bolts(both ends) are tight!
Old Jan 21, 2007 | 03:46 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
check to see if it is a puncture
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
