4x4 rear anti roll bar onto 3dr?
Old Jan 19, 2007 | 04:50 PM
wildheart's Avatar
wildheart
Default 4x4 rear anti roll bar onto 3dr?
Worth while mod or not?
And is it an easy swap?
Old Jan 19, 2007 | 10:34 PM
jon@work's Avatar
jon@work
Will only fit if you're using later semi-trailing arms. The sapph and escort ARBs mount in a different position to the 3dr ARBs.
Old Jan 20, 2007 | 03:21 AM
Alan s1's Avatar
Alan s1
As above saph and escos has a in board set up where as the 3 doors run out board set up
Old Jan 20, 2007 | 04:14 PM
wildheart's Avatar
wildheart
So thats a no then
Old Jan 20, 2007 | 06:50 PM
cossie604's Avatar
cossie604
tbh tho would you actualy notice any thing as you can control body roll via your coil overs?
Old Jan 21, 2007 | 11:11 AM
wildheart's Avatar
wildheart
Ive got crappy Avo's though
Old Jan 25, 2007 | 08:47 PM
ozcos's Avatar
ozcos
Its a fairly easy upgrade if you have the trailing arms to suit or mode yours.
I used the thicker escort bar and it made a noticable difference on tracks and very smooth roads.
But on very rough surfaces/ roads I found no rear roll bar was best.
I made alloy blocks to attach to shell as the 3dr is a different shape in this area.
The saph shell however has the fittings to take either rollbar.
Some new trailing arms from ford had the fittings for both inner and outer bar set ups.
Old Jan 25, 2007 | 10:05 PM
wildheart's Avatar
wildheart
Cheers mate,
Will have to have a word with my tuner and see what they can do
FlashRS
Sep 14, 2015 12:36 PM
IAN RS2k
Aug 18, 2015 07:51 PM
TrevCos
Aug 17, 2015 09:08 PM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
