HELP!
Old Jan 17, 2007 | 10:48 PM
r-s-turbo's Avatar
r-s-turbo
Default HELP!
ok think im bein a bit thick here possibly but i cant find anywhere to put my vacuum hose thru into the car 4 my boost gauge. are there any grommets in the bulkhead? where have other people put theres through??? also how how do i hook up the wiring to the lights on my car so the gauge is illuminated when my lights come on? i was jus thinking of temporarily hooking the wires up to my headunit so it comes on with that. any help much apprieciated!
Old Jan 17, 2007 | 11:07 PM
cabbyturbo's Avatar
cabbyturbo
Default Re: HELP!
iv put mine through the bulk head just left of the ecu into a gromit....and your wiring for your ilumination,id put into your light stalk next to your steering wheel...best to put a relay in so nothing gets hot or for a quick option put a inline fuse in so if it does get a bit hot it will pop the fuse and nothing else......
Old Jan 17, 2007 | 11:13 PM
NUTS RuS's Avatar
NUTS RuS
You can get through under the heater fan, there are two big holes under there, and as said t into the loom from the stalk for the sidelights.
Old Jan 18, 2007 | 07:44 PM
Rick's Avatar
Rick
Vacume hose through speedo cable gromet. Lights from the heater pannel - there's a nice connector there.
Old Jan 18, 2007 | 07:47 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Speedo cable grommet..and wiring to lighting stalk.
Old Jan 20, 2007 | 01:38 AM
r-s-turbo's Avatar
r-s-turbo
Thanks for your advice guys! much appreciated!
