Worth Replacing 4x4 Oil Pump When Doing a Rebuild?
Old Jan 17, 2007 | 10:56 AM
J9BBY's Avatar
J9BBY
Default Worth Replacing 4x4 Oil Pump When Doing a Rebuild?
Do these items wear out? Is it worth replacing when doing a full engine rebuild as these are rather costly, or can you get away with fitting a high pressure kit?
Cheers,
Pete.
Old Jan 17, 2007 | 11:06 AM
STUCOS's Avatar
STUCOS
Pete how can you call an oil pump costly,it's the heart of your engine,yes you can check for wear,but for the cost of a new pump i would always fit one,also dont fit new rings to old cossie pistons
cheeRS stu
Old Jan 17, 2007 | 11:18 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Just replace it, it's like 10% of the rebuild cost if that, but could save you needing another rebuild in 6 months time!
Old Jan 17, 2007 | 01:50 PM
J9BBY's Avatar
J9BBY
Cheers. That's all I wanted to hear. Just trying to justify the cost of the rebuild with myself.
Stu;
Why is this? Is this a general rule?
Cheers,
Pete.
Old Jan 18, 2007 | 12:42 AM
STUCOS's Avatar
STUCOS
Measure a secondhand cossie piston and you will find it has shrunk,due to the force induction
cheeRS stu
big_Rad
Sep 15, 2017 09:36 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Dubs44
Aug 21, 2015 02:42 PM
mrmann
Aug 20, 2015 11:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
