How do i fit this breather system.
Old Jan 17, 2007 | 10:15 AM
ken54231's Avatar
ken54231
Default How do i fit this breather system.
Can someone tell me where the 2 unhosed pipes goto on my engine.
Thanks.
Old Jan 17, 2007 | 11:10 AM
twinkle_2k86's Avatar
twinkle_2k86
i would say the bottom one goes to the block, and the other must go to the other side of rocker cover
Old Jan 17, 2007 | 11:16 AM
ken54231's Avatar
ken54231
I tend to agree with you mate , i am just not sure where abouts on the block the bottom one would go.
Old Jan 17, 2007 | 11:20 AM
PaulT's Avatar
PaulT
The pipe with the filter on goes to the metering head,
The pipe to the left goes to top left of the rocker
The bottom pipe goes to the block
The right pipe goes to the right on the rocker
If you want to vent to atmos with the filter just connect the others as above.
This is how my bailey seperator is plumbed
PaulT
Old Jan 17, 2007 | 11:22 AM
Oranoco's Avatar
Oranoco
Don't think you can vent teh KE-Jetronic to atmosphere. I know when you take the oil cap off the engine is supposed to die
Old Jan 17, 2007 | 11:52 AM
ken54231's Avatar
ken54231
So if i vent to atmos would i need to block up the hose connector on the metering head , and also where abouts on the block do i connect the bottom one to.
Old Jan 17, 2007 | 12:37 PM
Marc LJX's Avatar
Marc LJX
Take off the small pipe that runs from the right hand side of the rocker cover (Behind the oil filler cap) down to the block.
Where it enters the block, thats where the bottom of the breather should be connected to...
(Via a short pipe)
Old Jan 17, 2007 | 12:47 PM
Oranoco's Avatar
Oranoco
you shouldn't be able to vent to atmosphere because Bosch KE-Jetronic doesn't like air leaks and thats what venting to stmosphere is essentially.
Old Jan 17, 2007 | 12:59 PM
ken54231's Avatar
ken54231
Bit strange that Oranoco as im sure this came of an s1 , i see what you mean though , so really i need to connect that pipe without filter to the metering unit .
Old Jan 17, 2007 | 01:03 PM
ken54231's Avatar
ken54231
Ah right now i know where the pipe goes , cheers marc! and thanks everyone for the info , i will try and put it on at weekend
Old Jan 17, 2007 | 02:04 PM
JamboRS's Avatar
JamboRS
focus rs 1672
you can vent to atmo on ke jet,bung up the return breather hose on MH
downside now if you do have a boost leak anywhere its a bugger to know as the engine wont tell you now by cutting out,had mine venting to atmo for a couple of months and seems to idle better and be a little smoother too,maybe removin the dump valve aided that
RUBY123
Oct 22, 2023 12:04 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
