wanted pic of a standard escort turbo ecu
hello im after a pic of a standard rs turbo ecu as brought a ecu which im told is chipped i would just like to see the inside of a standard one to see the differents as the inside of mine hasnt got any marks to say what chip it is or if it is just a standard one
Does it have a clear window on the chip ?
If so its modified
You may have to remove an aluminium strip on top if its fitted
(2 screws either side of chip and some twisty tabs)
There will be NO way to tell what stage or who did it unless you have
a sticker with the exact info written on it in PLAIN english.
If so its modified
big_Rad
Sep 15, 2017 09:36 AM
rog
Sep 4, 2015 12:10 PM
