I want to lose rotating mass, clutch and flywheel first
Old Jan 11, 2007 | 08:15 PM
Mr C's Avatar
Mr C
Default I want to lose rotating mass, clutch and flywheel first
What can be done to reduce rotating mass on the cossi YB? I have a trackday car, 2wd sapphire cossie for drift and track use and want to make the most of what little power I have 330bhp about the same torque MAX So what is available and whats recommended? I was thinking a 7.5" flywheel and clutch is definately the lightest out there and twin plates are available, im thinking of changing to hydraulic actuation too so feel and weight isnt too important.
The clutch will be dumped often and generally used hard, it cant slip and must not cost a fortune. IDEAS?????
Old Jan 11, 2007 | 08:19 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Why do you want to loose the rotating mass???
Bri.
Old Jan 11, 2007 | 08:22 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
better respons in generel
Old Jan 11, 2007 | 08:25 PM
*Bri.4.b.Cos*
True will rev more freely, but will you not loose a chunk or torque too, due to having less inertia (sp)
Bri.
Old Jan 11, 2007 | 08:44 PM
Mr C's Avatar
Mr C
I want to help the engine out where I can, I can afford to run a 300bhp YB so want to make the most of it, will losing weight off the transmission have negative effects with regards to driveability and torque etc? Would the gain in response be enough to offset the loss of torgue, Circuits are prety flat?
Old Jan 11, 2007 | 09:19 PM
big_wig_074's Avatar
big_wig_074
when you lighten flywheels you generally upset the driveability mate,it becomes more difficult to pull away and turns a nice driving road car into a small puppy on a lead type affair!going up hills etc is affected.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
A.t.p
Oct 23, 2015 07:54 PM
fordrallycar
Sep 30, 2015 07:57 PM
