movement in drive shaft joint
How much movement is accptable in your driveshaft joints? Ive fitted my shafts to the diff and hubs and always though the slack I had in the drive was in the old diff but it is actually in the outer CVs, you can move the wheels a good couple of cm before movement is taken up by prop- diff and shafts which all feel pretty good, whats the allowed amount if any or are my joints about had it
Mark V8
Sep 13, 2015 09:34 AM
