can you tell from reg plate if an xr3i is 105 or 130?
the only thing i can think of 1st hand is the 105 had rear drums and 130 had discs(not 100% tho),theres another cuple as well but cant think any at moment,but sure sum 1 will correct me if wrong or any more!!!
i'm good ta...
few simple tells
does the car have rear discs? 260mm front brakes, should be close to the inside of the wheels on standard 14's is it lift up reverse...
does it rev to 6750? pulling to the limiter, if no to any of those some of it isn't 130spec
few simple tells
The only difference between the 105 & the 130 is the 130 had a bigger throttle body housing.So all those escort and mondeo 105's out there.If u can find a 130 throttle body then fit it.
Paul.
Paul.
that number lpate isnt on the ford ETIS system, it must have been re registered (like if its had a private plate on at some point), if you have the vin, i can x ref
