How do you fit a breather and catch tank?
as title, i have a breather, which has 4 ports and i want to fit a catch tank as well, how does it all connect up again? i know one port on breather goes to camcover inlet. and one vents to atmosphere, where do the others go?
cheers for any help
cheers for any help
if its for a cossie
1 to cam cover
thers a an adptoryou can buy that fits in a hole under the turbo into the crankcase
you have to remove a bolt to fit teh adaptor there
then one to the breather flametrap on inlet side
other to atmosphere
1 to cam cover
other to atmosphere
cheers for any help
cheers for any help
On the bailey, you have a large hole in bottom - this is to vent to atmosphere (possibly to catch tank?)
The small one on the bottom of the tank goes to the block on the turbo side (using an adaptor and the existing threaded blanked hole under turbo.
This leaves two on the top the same size.
I dont think it matters which way round these go, but for assistance, if the holes are pointing towards you, the left one goes to the cam cover (via a new drilled hole in the pre located space), and the other is connected to the existing kidney box (remove other existing pipes and fire trap filters!)
Hope this helps
JJ
steerfromdarear
28
Jan 29, 2016 06:14 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
