W....T....F....
Originally Posted by COMEDY DAN
What a sack of shit.
I cant see 5k's worth of car there sadly.
A jag engine out of an old Jag XJ6 and a fibre glass surf bourd on either side.......lol
why did the builder not just put a 2.0 in it like everyone else does,
"your buying the car and the idea"
you can ram both of them up your arse mate!!!
Originally Posted by jhw
Hi this is your chance to ow a one in a million capri/moggy joint together we just picked it up today just a nother abandoned project.
This car was done about 10 years ago and was on the road for about 5 years it is almost complite look as if it needs axel putting back on all the shocks with coil over x 4 are their it has got a ford v4 fitted complite will try to start tomorrow see how it sounds but dont hold your breath as their is a electronic ignition convertion fitted and i cant see the module perhaps it is in the boot loads a spares there see pictures
1. Jaguar back axel (with convertion kit professionaly done to fit axel to capri or escort)
2. ford v4 complite engine fitted (everything is there should run)
3. Ford front brakes with morris minor suspencion
4. 2 x escort 13inch wolfrace wheels
unfortunatly hasnt got a log book
This car ia amazing the convertion has been done professionally not bodged done ten years ago dosn't have to be tested.
You nare looking at a hobby but with the right tlc it could be a stunner
DEFFINATLY WORTH A LOOK
Originally Posted by charlie luciano
You can take that thing and throw it off the nearest cliff!
Luciano
Luciano
I can't beleive u dont even get the wheels et with it..what a load of bullocks, only decent thing is the engine
Luciano
Luciano
PMSL at the centre driving position, ie they plonked a fookin seat on the tranny tunnel with NOWHERE for the freakin pedals to go, but it does say you have to work that bit out yourself
